SOHC.co.uk Forums > CB500/550
Trouble mounting new HM 323 pipes
Honda Al:
I'll keep you updated on my progress with CMS regarding the leaky muffler. So far, so good and they replied back quickly asking for photos.
Honda Al:
--- Quote from: Honda Al on June 14, 2016, 08:16:25 AM ---I'll keep you updated on my progress with CMS regarding the leaky muffler. So far, so good and they replied back quickly asking for photos.
--- End quote ---
Photos have been passed onto the suppliers for comment.
flatfour:
I ordered a kick starter return spring from CMS for the 500/4 about two years ago, only to find on unpacking it that it was completely different to the one fitted and also the one shown on their parts drawing. Return was no problem and they identified a packaging issue, i.e. wrong spring, correct box.
I was offered a refund or the option to wait for a new part, which was the route that I took. In the meantime, John Wyatt sent me a used spring from a bike that he was preparing for track use, where the kick starter would not be needed.
The correct spring from CMS arrived about two weeks later, so I now have a spare in case it happens again!
I have, over the years bought quite a lot from CMS and found them always happy to talk over the telephone, with a named contact in case of problems after their returns procedure has been initiated.
deltarider:
Back to the subject. Ashimoto and others, are you sure that every CB500 Four is supposed to have the brackets on in- and outside of the frame eye? Reason I ask is that this morning I phoned with one of the SOHC Four shops in Holland. When I asked the mechanic for advise, he told me to mount the exhausts so that both in front they sit well as in the rear have the tubes close enough (obvious). 'If that means both brackets are on the outside, so be it.' He added that sometimes he himself and in spite of mounting newly ordered brackets, had to have them both on the outside. What's your experience?
Honda Al:
--- Quote from: deltarider on June 15, 2016, 09:45:50 AM ---Back to the subject. Ashimoto and others, are you sure that every CB500 Four is supposed to have the brackets on in- and outside of the frame eye? Reason I ask is that this morning I phoned with one of the SOHC Four shops in Holland. When I asked the mechanic for advise, he told me to mount the exhausts so that both in front they sit well as in the rear have the tubes close enough (obvious). 'If that means both brackets are on the outside, so be it.' He added that sometimes he himself and in spite of mounting newly ordered brackets, had to have them both on the outside. What's your experience?
--- End quote ---
I did try this when I was stuggling and it didn't make any difference. They still didn't line up!
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
