Author Topic: Compression loss and rough running.... Saga  (Read 5975 times)
Offline Clem2112
  • Midlife
« on: June 21, 2016, 09:59:09 PM »
Many months (years?) of head scratching over my poor running but totally re-built motor may nearly be over ?
Lack of any real pull and bogs down under load.....just about gets to its MoT test.
Re-tracing events prior to this....
The head gasket got replaced again after removing the cover to retorque when some stripped threads in the head meant it had to come off for repair with inserts.
The second gasket was also genuine Honda and the retorque was done after an initial running.
Eveything else has been checked and re-checked over and over.....ignition, carbs balance and float height fine, tappets set, camchain tension ok... Nothing left to do.....but hard to start the thing  !
Once it is going and warmed up it idles quite steadily but revs up a bit like like a twin.... Kind of harsh and the exhaust note isn't right. Plug colour is ok though. No smoke either.
Did a cold compression check with carbs on and off with the same results....170 150 150 170 psi both times. Then did the check after warming up......150 150 150 150.
Counter intuitive I thought....compression worse when hot  on cyls 1 and 4 ??
I can only think the gasket is leaking between each pair of cylinders where the clamping pressure is weakest/ gasket narrowest?
When cold it seems that cylinders 2 and 3 under compression lose pressure to the outer cylinders which are on their inlet stroke....2 and 3 fire with 1, 4 compressing so no loss of pressure?
Is this right?... Assuming 1,3,4,2 firing order is right.
Maybe re torquing again will work, maybe not?
Probably a new gasket, seals.....££
Re: Compression loss and rough running.... Saga
« Reply #1 on: June 21, 2016, 10:07:29 PM »
my thoughts are carb issues,
 check the slow running and emulsion tubes/needle jet etc,
 use carb cleaner and spray out the internal drillings .
Offline Clem2112
  • Midlife
« Reply #2 on: June 21, 2016, 11:11:34 PM »
Been there already.... Several times.
New needles, emulsion tubes, main jets, pilots, seals, floats !
No keyster stuff either.
....ultrasonically cleaned the bodies too. Bowls are clean.
All passages clear.
« Reply #3 on: June 22, 2016, 06:53:24 AM »
The way you write it suggests points gap/condenser/timing to me
Offline Clem2112
  • Midlife
« Reply #4 on: June 22, 2016, 08:06:56 AM »
Even tried putting the points back on......
Have dynatek ignition and dyna 5 ohm coils......times up fine.
Real question is the compression iffy ?
« Reply #5 on: June 22, 2016, 10:57:34 AM »
For a rebuilt engine that's not yet bedded in they are pretty good compression readings, assuming that it was re-bored or re-ringed with a hone. I would swap the DynaS for a set of standard points if you still have them. DynaS has been plagued with failures that do look similar to this. Temporarily going back to points will eliminate the possibility of electronic failure.
Offline Clem2112
  • Midlife
« Reply #6 on: June 22, 2016, 12:12:38 PM »
a bit more info...
It has covered a few hundred miles in shortish outings since the re-build,  during which time the carbs have come off a few times for float valve leak issues, new jets , floats too
 - to rule out those as the culprits !
A set of new OE points (with a DSS backplate setup) went back in this year to eliminate the Dyna ignition as a possible issue. Strobed too. No better !
The last time the head came off after about 500 miles, all four bores still had honing marks and looked very new (0,25 oversize on all 4) and the piston crowns had a sooty look but not too bad.
The cold engine readings seem ok to me too.... but the difference seems suspicious ie over 10% and 1-2 and 3-4 pattern.
Then the warmed up readings seem very weird unless there is something going on with
the gasket (no leaks anywhere around the joint either!)... maybe I have "over-thought" the possible reasons why ?
« Reply #7 on: June 22, 2016, 12:32:57 PM »
Wow this is going to be a tough one sounds like you already covered most things.
Just a few thoughts. You say you strobed it, did you rev the engine with the strobe attached to check the advancer in case its stuck in one position? Also are you sure the coils and leads are okay, and all low tension wiring has good joints and is connected correctly. Also check the negative lead from the battery to the frame (earth) is making a good connection ie. clean away any paint etc under the lead and is the lead itself good. The symptoms sound like ignition problems of some sort.
Offline Clem2112
  • Midlife
« Reply #8 on: June 22, 2016, 12:53:05 PM »
Think the electrics and wiring are good but I will go round these easily overlooked areas again just to be 100%.
Nice to think it could just be something simple and cheap to fix !!
Head off to find nothing would be frustrating !
btw the 12v feed to the ignition goes through a relay so I could bypass the old harness wiring (kill switch also "new" as I bought OE switchgear too) and ensure a healthy supply to the coils (new Dyna 5 ohm, new copper leads made up and sparks look good to me)
Advancer seems to advance and retard ok with the timing light to check it moves both ways freely.
« Reply #9 on: June 22, 2016, 07:53:32 PM »
Just a quick thought, as Roy has pointed out and it seems you've got a fairly comprehensive view of the status of most current parts and setup,  have you read the MrT post on his 550 as it appears that his problem is coming from the dyna coils and has given him a right runaround in trying to get to the bottom of it.
They are fairly new in his case as well and have given some very strange symptoms, maybe worth a check with some other coils to at least eliminate something simple. He also has visible sparks with his.
Compressions, as previously stated don't seem bad and I wouldn't first suspect those as your cause. Regarding the hot reading being lower, it might be worth just checking the tappet gaps when hot, not measure them but open the caps and just rattle them to check if you've lost any space that could keep the valve marginally open.
Offline Clem2112
  • Midlife
« Reply #10 on: June 23, 2016, 10:36:28 AM »
I will check the valve clearances again.
As well as checking the earthing etc .. although the starter spins well so the main frame/engine to battery earth strap must be ok?
Will also change the plugs to D8EA ie without resistors.
Currently I have Iridiums which have internal resistors -   some say that 5K caps and R plugs is not good for the spark.....??
Offline Clem2112
  • Midlife
« Reply #11 on: July 05, 2016, 09:16:42 PM »
Well it's not the spark plugs. D8EA's made no difference.
Still haven't learned how the compression can drop on the outer cylinders once things are hot.
Has to be head gasket ?
« Reply #12 on: July 05, 2016, 09:30:36 PM »
 does the engine leak oil  from the head Gasket area?
Offline Clem2112
  • Midlife
« Reply #13 on: July 05, 2016, 10:49:27 PM »
No...dry all the way round.
My original 400/4 did though.... down the LHS but it still ran ok.
Couldn't the seal fail between cylinders?
