Author Topic: Oil pressure issue / motor rebuild  (Read 60209 times)
Re: Oil pressure issue / motor rebuild
« Reply #120 on: October 05, 2016, 08:17:55 AM »
Feeling for you Dave. I blasted my 250 engines only the outside but only after totally sealing everything on a fully assembled set of cases with no internals fitted and then pressurizing the inside to check for leaks.
How about this for an idea ..a few of us  must have quite a few old shells lying about, that may not be too worn. How about experimenting with them to try to ascertain where you have lost 'clearance', then you are not going to fk up valuable new shells. This is going to be totally frowned up on here but why not get some pieces of copper foil and make little gaskets for the centre bearing mating surfaces. Put your crank in but only nip up the centre bolts and see if you can regain your clearance, using Plastigage to measure it. I think line boring would be quite hard but it depends on who you know and what equipment they have, definitely cheaper to get replacement cases if you had to pay commercial rates for that job.
If you find they blasted the bearing housings that the shells fit into then IMHO I  would think your cases are toast.
« Reply #121 on: October 05, 2016, 09:06:09 AM »
It's a real shame to get caught into something like this when you just wanted a nice bike to ride. I does look like you are right regarding the loss of tolerance to the mains though. I know when we are involved in stuff of this age there are problems to be taken on but you'd not anticipate something so obscure and fundamentally wrong.
There is a process other than line boring that could realistically get those cases back which is engineering scraping. It was routinely done to get bearings into tolerance in some fields particularly when people would have been making up soft bearings for large machinery. It involves using something like a correctly sized mandrel to check for high spots with engineers blue, then physically scraping the high parts away and re-checking until the hole accurately matches the mandrel.
To expand on your method Ash but instead the opposite direction, you could linish the back of the shells with a very fine grit paper while miking them to relieve the space over an arc at the deepest part of the shells then check crank fit in them with engineers blue to bring them into tolerance and roundness.
« Reply #122 on: October 05, 2016, 01:00:38 PM »
Thanks for your replies, here's a couple of pictures from the garage last night, the cases are stripped right down now, though I just have to remove the transmission.
Every picture tells a story:
There is a slight lip at the back corner on each side of the barrel overhanging the cases, A smart whack upwards each side did the trick - daylight at last!
You can see that the pistons are stamped '25' - the motor had just had a rebore, great news and it explains why there was no sign of wear in the barrels. Clearly someone spent a good deal of money on this bike, only for it all to go breasts upwards over such a tiny issue, resulting in most of the new stuff, which included brand new rims and spokes, being virtually zero miles, because of the crank FUBAR. Thats why its well worth doing right, IMHO.
I would like to save these cases if I can, for all the trouble the 'whatever' blasting has caused, the external finish, polished and then painted (I didn't realise until I chipped it trying to prise the barrels off) is super, and the cases look like new. I'd struggle to get another set that good, particularly as they would definitely not be going anywhere near a basting cabinet! IDK if the threads were masked, or recut, but they all look fine, unlike a set of BSA cases I once bought at an autojumble, when I was young and stupid,that had been blasted and turned into scrap.
I'd rather not go down the packing route, Ash, I'd prefer sound engineering to trial and error, and also the packing would have the effect of pushing the crankcase halves apart unless you made a copper gasket for the whole of the crankcase - It could leak like a sieve, not support the transmission bearings properly, or if it torqued down OK all be under stress. That reminds me, as Hondaman says, if you can line bore a 'seasoned' motor, that has already gone through many heat cycles, you get a smoother motor than one that was line bored when it was virgin metal, something that race engine builders use to their advantage.
The bearing carriers aren't factory finish any more, but very smooth. Its the centre line measurement that has been messed up - removing some of the circle has caused it to become slightly oval -  they should be possible to line bore out to spec, as they are tight not slack - you can make a hole bigger, but not smaller!  ;)
I could have a go at scraping as suggested by K2-K6, at virtuall zero cost, but trial and error with 10 shells to go at sounds a bit of a mare, and it would only take one error.
According to the HMC crank bulletin, bearing support 'A' tolerance (which would let me use my yellow shells with Ash's AAAAA crank) is 39.000 to 39.008 mm. If necessary the bore can be as big as 39.024, but obviously thats a set of different shells.
I'm going to send an email to Quasar engineering in Stockport http://www.quasarengineering.co.uk/ who fine tuned my Harley crank for not a lot of money, see what they quote / think before I make any irreversible decisions.
« Last Edit: October 05, 2016, 01:11:24 PM by MrDavo »
« Reply #123 on: October 05, 2016, 01:16:16 PM »
It was only a suggestion Dave.. personally, I would get replacement cases but if you want to preserve numbers then that's possibly not the route to go. I assumed it was only the centre 'pillars' that were nipping up the crank so small bits of 1 thou copper foil may have just confirmed that the problem is mainly on those and not the outers, but you could probably ascertain that anyhow from a decent bore gauge measurement, wiith the crank out and the cases bolted up.
I checked the cases the crank I sold you came out of as below and apart from one outer half, all the shells are still there if you wanted to try used, not particularly worn SH shells to check whatever method you come up with is satisfactory without trashing 100+ quids worth of new ones.
« Reply #124 on: October 05, 2016, 01:21:36 PM »
I would also bin those crank cases and seek a replacement. If the bearing surfaces are damaged, then all bearing housing will be beyond spec, this will include bearing and oil seal housings.
Offline Chris400F
« Reply #125 on: October 05, 2016, 02:25:21 PM »
Given the note you found that you posted earlier in this thread about a matte surface bonding with well over double the bonding force of a smooth surface, and the fact that the blasting removed enough metal to give the problems you have had, if you keep the cases would the first step be to get the mating surfaces skimmed to get them flat and smooth?
« Reply #126 on: October 05, 2016, 02:58:13 PM »
What Trigger says is food for thought, as he knows more about these motors than most. Will the couple of thou that uses up my crank oil gap have the same effect on a the housing of a large ball bearing or a rubber seal though? There are no signs of trouble with the gearbox and final drive bearings, no witness marks or roughness. I do take your point though.
Anyway, until something else turns up, these cases are what I've got.
Yes Chris, I'd like to get the mating surfaces lightly skimmed, but then again every thou makes the problem worse.
« Reply #127 on: October 05, 2016, 03:07:14 PM »
Agreed but depends if blaster has blasted centre bearings more than outer ones  (smaller area too), which I suspect,  as its only when he torques centre bolts down it nipped up or was I wrong on that ? Best thing is to clamp it all together with no crank etc  and measure the bearing bores for ovality IMHO
« Reply #128 on: October 05, 2016, 03:36:20 PM »
There is very little disturbance to the bearing housings as far as I can see, they must have been gentle there. The trouble is the metal removed from the centre join as far as I can judge, there is no trace of the original machined finish. :(
Ive sent Quasar this email earlier today, we'll see what they think, they are only 9 miles away so it won't hurt to get things accurately measured, at least.
Quote
Hi, I have a 1971 CB750 Honda four cylinder classic bike.
I bought the bike already restored, but with damaged main bearings. I have changed the crank for another, known to be in very good condition, measured the journals with a micrometer and fitted the correct shells. When I tourque up the crankcases, the crank locks up, just as the final torque setting is reached. I believe that the problem is that previous media blasting of the cases has removed a few thou of alloy from the crankcase centre joint, meaning that when the cases are tightened up the crank journals are slightly out of round, nipping up the required oil clearance.  I have the Honda spec measurements for the bearing shell housings we are talking about a range between 39.000 and 39.008 mm I.D. for the shells I have.
If I brought the cases to you, (I am in Stalybridge) could you measure the crank journals' internal diameter for this, and if possible line bore the journals back to spec?
What sort of cost are we looking at?
The alternative is to use another set of cases, but I would like to save the originals if I can.
Thanks, Dave
Offline Chris400F
« Reply #129 on: October 05, 2016, 03:51:59 PM »
Agreed, and it would be more work and more money.
But can you be satisfied that the surfaces as they are are still 'true'? As there is no way of knowing exactly how much metal the blasting removed it is quite possible more has gone from some places than others. Maybe get an opinion from Quasar, to be sure this wouldn't be a problem.
« Reply #130 on: October 05, 2016, 04:08:37 PM »
Two things
(1) a large piece of plate glass from a glazing firm and some very fine compound will check if the case joints are flat
(2) Back when i did a lot of Ford engines if a big end knocked it was common practice for the rod end to need resizing as they ovaled
« Reply #131 on: October 05, 2016, 07:25:39 PM »
(Attachment Link)
I 2nd Ash with this, torque the empty cases and get an engineering firm to precision measure the case bores. You may only be able to measure the outer bores accurately enough but that will do. If they measure small or oval your cases are toast and anything you try will not be acceptably accurate unless your an old school engineer with amazing skills. Sounds to me like the case blasting has removed material from the mating faces, and thousanth of an inch on each case would be more than enough to cause your problems. Good luck with it.
« Reply #132 on: October 06, 2016, 12:33:33 AM »
I'll see what the engineers say in reply, cases have been linebored in similar circumstances, but one worry would be the deck height of the cylinders, you would effectively move the pistons nearer to the valves! - in fact you already have by taking metal of the crankcase face.
Ash, you don't think Freddie's unstamped cases would be any good? He doesn't say what year they are, though I take his claim that they'd fit all years with a big pinch of salt, can anyone shed light on this?
« Reply #133 on: October 06, 2016, 06:17:12 AM »
I have answered the question many times about these unstamped cases but, not on a forum. I can see that these case's are a late shape and would be suitable for a K3 to K6 .Possibly a F1 if I could see the crank case breather.
« Reply #134 on: October 06, 2016, 07:37:55 AM »
If you want to spend some time before going to an engineer here is what I would do:
Fit all the knackered shells then replace 1 journal at a time with the new and torque up to see if the crank locks up checking all journals individually.
If only one journal locks up the crank try fitting the shells for smallest case and biggest pin then try again, if all lock it up i would look for different cases or a complete engine using the rest of the bought engine as spares.
As somebody else said the gearbox bearing clearances will be wrong as well and you will be clamping them too tight, and whist they are robust steel cages I don't think it's a good idea.
As too altering the piston/head clearance that is minimal considering you can skim both head and cylinders
