Project Board
Seat base
Topic: Seat base (Read 11554 times)
onethumb
SOHC Expert
Seat base
July 17, 2016, 11:40:05 PM »
Hi all, going to start making th seat base soon and wanted to ask for ideas. Thinking of using 2mm steel or 3mm aluminium. Then there was the thought of a polly nylon kind of material. Then today I saw the old original seat unit that is in quite good shape which I was going to sell as the cover is 8/10 the unit 7.5/10, but as it's just sitting there ready to be used.
Any ideas or thought ?
Thanks.
yozzer74
Re: Seat base
July 18, 2016, 05:17:36 PM »
I would make one. as the original probably won't suit the style your going for . And it won't cost the earth to do .
Valentinik
SOHC Member
Re: Seat base
July 18, 2016, 08:33:29 PM »
What style seat are you going for? I made my brat style seat (flat with a kick up at the back) out of 3mm aluminium and it is plenty thick enough. I wouldn't want to go any thinner in aluminium though.
Mike
onethumb
SOHC Expert
Re: Seat base
July 18, 2016, 10:12:33 PM »
Yozzer, I really didn't want to destroy a pretty good seat unit.
Valentinik ive got a 20deg kick up on mine, did you weld any of yours, how did you attach bits to the unit. I can't weld aluminium.
yozzer74
Re: Seat base
July 18, 2016, 11:01:51 PM »
Use rivets to fasten things on to base
Valentinik
SOHC Member
Re: Seat base
July 19, 2016, 03:59:43 PM »
I can weld aluminium but mine was a flat piece that I then put a bend in to suit the kick up of the frame section. I used rivnuts into the aluminium plate and then welded 2 flat pieces of steel across the frame for the bolts to go into. I'd planning on using more rivnuts to hold all of the electrical items to the underside of the pan too.
If you want any specific pictures of mine just let me know and j can take some.
Mike
onethumb
SOHC Expert
Re: Seat base
July 19, 2016, 05:11:52 PM »
That would be a big help. Thanks.
Valentinik
SOHC Member
Re: Seat base
July 19, 2016, 07:15:43 PM »
Here's a few pictures, if there's anything more specific you want taking, just let me know.
Mike
onethumb
SOHC Expert
Re: Seat base
July 19, 2016, 09:11:45 PM »
Nice job on the loop. Thanks
yozzer74
Re: Seat base
July 19, 2016, 10:39:15 PM »
Onethumb if you look on pops400 build thread on page 6 I think I showed him how I fitted my seat if it helps you out .
onethumb
SOHC Expert
Re: Seat base
Reply #10 on:
July 20, 2016, 12:53:57 PM »
Thanks yozzer I will check it out.
onethumb
SOHC Expert
Re: Seat base
Reply #11 on:
July 20, 2016, 05:20:27 PM »
Nicely done yozzer. Where did you get the seat done?
yozzer74
Re: Seat base
Reply #12 on:
July 20, 2016, 05:43:43 PM »
Which part the cushion or the actual seat hump
onethumb
SOHC Expert
Re: Seat base
Reply #13 on:
July 20, 2016, 10:45:18 PM »
The cushion.
I know who did your seat, he's one of the nicest people I've ever spoke to on the phone.
yozzer74
Re: Seat base
Reply #14 on:
July 21, 2016, 08:12:37 AM »
It was a place in Sheffield .there just a car upholstery firm .I'm sure there will be some thing similar near you .
Project Board
Seat base
