Author Topic: Very stiff turnover  (Read 9691 times)
Offline masonmart
Very stiff turnover
« on: July 28, 2016, 05:01:12 PM »
Just finished assembling a CB500 engine. I'd had to change the crankcases because they were cracked and I couldn't get the right main bearing shells for the replacement case/crank match. Anyway, what I've found is that even with no plugs in it's difficult to turn it over on the kick start. I can turn it over by hand using the generator. I had the casings all Cerakote coated and I have a horrible feeling he may have done the insides and the mains and camshaft bearings are gripping but maybe not. It has a 605cc kit fitted but it was never run.
This is my first build and I'm sure that the gearbox is fine and the valves and everything else does what they're supposed to do but is this something that can be seen on rebuilds and are there any fixes
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
Re: Very stiff turnover
« Reply #1 on: July 28, 2016, 05:57:52 PM »
did the crank turn easily before you fitted the pistons and barrels?
« Reply #2 on: July 28, 2016, 06:05:02 PM »
Did you plastigauge the shells and make sure all clearances were correct ?
How did you get it clean to Cerakote coat the engine ?
« Reply #3 on: July 28, 2016, 06:08:09 PM »
I once made the mistake of using Loctite bearing fit to the shells and that made the crank very stiff to turn.  After scraping the stuff off, it was OK.
Offline masonmart
« Reply #4 on: July 28, 2016, 06:35:47 PM »
John, it seemed to turn nicely before I put the top end on but I didn't check it again until I'd finished installing the top end. I improved it a bit by taking the head cover off and rubbing down the camshaft bearing surface a bit but still not enough improvement.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline masonmart
« Reply #5 on: July 28, 2016, 06:41:48 PM »
No I didn't measure the clearance, I measured the crank dia. and case dia. and they were the same for the ones I couldn't get the correct shells for as the ones I could so I assumed it was OK.
The exterior was shot blasted to clean the alloy for coating but I asked him to mask off the inside which I believe he did. Looks great but I was a bit careless in how I got it done.
I believe that I need to take the engine out again and rectify the problem properly. Shame because on the bike it's in I have to put the bike on it's side and take the frame off the engine.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
« Reply #6 on: July 28, 2016, 07:32:20 PM »
Sounds a bit weird that it will turn by hand but, not on the kick, when your body weight is a lot more force. Are you sure that the kick start is not jammed ?
Offline masonmart
« Reply #7 on: July 28, 2016, 10:19:10 PM »
Sorry trigger, I'm turning the kick start by hand not foot as the bike is up on the ramp. Normally with the plugs out it is still easy on most bikes.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
« Reply #8 on: July 28, 2016, 10:51:03 PM »
I find it is stiff by hand .!!!
 did I really say that ?????
 let me rephrase it,
 the kickstarter is for feet !!
  see what it feels like with the plugs out ??
« Reply #9 on: July 28, 2016, 10:58:01 PM »
 ;D ;D ;D ;D Naughty boy John.
Trig says he wouldn't be able to turn the engine over by hand with no plugs in if the engine is good and tight. He says it's not a cranking handle, it's a kick start, the clue is in the name  ;) ;). Unlike my 400/4 which he fires up using the kick start by hand  ::) ::)
« Last Edit: July 29, 2016, 06:58:04 AM by Nurse Julie »
« Reply #10 on: July 29, 2016, 06:42:21 AM »
Ah but does he manage to start you by hand as well as the bike (Sorry couldn't resit that one Julie!)
« Reply #11 on: July 29, 2016, 07:03:20 AM »
:o :o :o :o :o
Back to original thread me thinks  ;D ;D ;D ;D
« Reply #12 on: July 29, 2016, 12:03:40 PM »
:o :o :o :o :o
 good idea !! how about you leave the plugs out,squirt some light oil onto the piston ,then kick it over a few times,and if that
feels a bit better,spin it on the starter ,also check you have oil pressure,maybe remove a couple of  tappet covers to see the oil
in the top .
 wen you use the starter,do it for arround 5 seconds at a time,so you don't overheat it
Offline masonmart
« Reply #13 on: July 29, 2016, 06:21:26 PM »
The bike is on the ramp and not wired up yet so I can't try the starter. All of the rotating bits were oiled as assembled. I've tried taking off the head cover to unclamp the camshaft and that eased it off a good bit.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline matthewmosse
« Reply #14 on: July 29, 2016, 07:06:26 PM »
Are all the tappetts set right? Or might it just be the effort to turn over and compress valves. It is easy to catch the rockers against the valve stems when putting the cover on. It does seem the problem is top end related. I'm a bit dubious that the rockers would make it that hard to turn over if everything was right, pretty sure mine turn over ok on the kickstart even only turned over by hand, though a good kick has always been the requirement for starting it. Turning it over on the electric start does not require any more wiring than a jump lead to earth and another to the starters lead or just wap it onto the battery positive terminal as long as you are prepared for the sparks, it works fine.
