Author Topic: My cb750 scrambler build. Restart  (Read 42501 times)
Offline onethumb
Re: My cb750 scrambler build. Restart
« Reply #60 on: November 07, 2016, 09:18:50 PM »
The tyre guy said the same. Don't know if to buy a new chain with a couple of extra links or go with the original and see how much slack I can get with it. Can you tell me where to look for some extra reading?
Offline yozzer74
Offline yozzer74
« Reply #62 on: November 07, 2016, 09:22:09 PM »
Read this thread it's quite good and on same lines as yours
Offline onethumb
« Reply #63 on: November 07, 2016, 09:24:57 PM »
Thanks buddy.
« Reply #64 on: November 07, 2016, 09:34:23 PM »
To set the chain tension,  remove shocks, pack wheel up until the centre of both sprockets and the swing arm pivot are all in one line as close as possible then tension chain to give just a small amount of slack (about  10mm)  and tighten wheel.
Then put shocks back on, and measure the slack in the chain to give you an in use set point for future adjustment.
If you set it too tight with the swinging arm extended downwards then as you ride it, when the suspension compresses it will go to tight at its longest point and pull the hell out of the bearings,  particularly the gearbox output one.
Build looks good by the way.
Tires look good,  I've used them on lighter bikes (kdx250) on the road and they are pretty good but squirm quite alot with front brake use so may take a bit of care to get the feel of them if you've not ridden with them before especially with the weight you'll be carrying on this bike.
Offline onethumb
« Reply #65 on: November 07, 2016, 09:59:59 PM »
K2-K6 thanks for the kind words and the information. Just read the link Yozzer put up and it says the same, yours is a little easier for a first timer like me to follow.
I'm hoping that riding my 1998 XR250 on the road with mud tyres on will be good practice.
« Reply #66 on: November 07, 2016, 10:51:29 PM »
Oops, I didn't see Yozzer's link, apologies for that. It's good to get it setup right though to avoid any problems.
As you've got there with the xr you get to make a bit of allowance for them as they aren't so precise as a road tire. Be interesting to see what you think of them on this bike when you've got it going.
Are you just going to ride it on the road or something a bit more adventurous with it?
Offline onethumb
« Reply #67 on: November 07, 2016, 11:03:24 PM »
It's for the road, maybe a trip to the beach and it might go on the grass when I park it at a show or something but the build was all about the bringing back an unloved bike that had been in a shed  since 1998 and giving it a new lease of life. And in process teaching me a few things as well.
Thanks for the heads up about the tyres though, the bloke at the tyre shop said he'd had a lot of good feedback from these but this was the heaviest bike he'd heard of them being fitted too. Still nothing ventured nothing gained.
Offline onethumb
« Reply #68 on: November 16, 2016, 09:51:44 PM »
Right then the fronts built up with the scrambler bars.  I think I like them.
Offline yozzer74
« Reply #69 on: November 17, 2016, 07:12:23 AM »
It's coming on looking good
Offline onethumb
« Reply #70 on: November 18, 2016, 05:13:12 PM »
Cheers dude. Just got my seat back. I'm proper pleased.
Offline yozzer74
« Reply #71 on: November 18, 2016, 05:42:03 PM »
Pics then??
Offline onethumb
« Reply #72 on: November 18, 2016, 05:51:00 PM »
Sorry. Here you go.
Offline yozzer74
« Reply #73 on: November 18, 2016, 06:03:56 PM »
Pmsl looks nice that did you have it made
Offline onethumb
« Reply #74 on: November 18, 2016, 06:09:56 PM »
Thanks dude. I made the base then had it covered professionally by a chap in Buckinghamshire, AJ trimmings. He's done it in leather for me. The flutes are at 1" 1/2 spacing all finished in black stitching.
