Other Stuff
Tricks & Tips
Battery for converted 72 CB500
Topic: Battery for converted 72 CB500 (Read 6147 times)
cantarauk
SOHC Member
November 01, 2016, 09:29:30 PM »
I am currently converting a 72 CB500 and am asking the experts here for advice on whether a Shorai LFX14A2-BS12 would be adequate for my build. The electrics are going to have a complete overall and I will be replacing all legacy with newer components such as a motor gadget M-unit, new R/R, and then LED headlight, LED brake and indicators. The ignition will be replaced with Dynatech coil and ignition system.
Does anyone have experience with smaller batteries in their builds and what should i look out for ?
Glenn
'72 500 Build
http://forums.sohc4.net/index.php/topic,160871
cantarauk
SOHC Member
Re: Battery for converted 72 CB500
November 01, 2016, 09:43:15 PM »
I Should add that I intend to use kick to start but would like the option of push start
'72 500 Build
November 02, 2016, 09:09:14 AM »
need the full battery specs to comment. AH etc
cantarauk
SOHC Member
November 02, 2016, 09:47:40 AM »
Hi Bryan
Battery specs are as follows:
LFX14L2-BS12
Voltage (Pb Eq) - 12V
A/Hr (Pb Eq)- 14
CCA (A) - 210
Max charge rate (A) - 14
'72 500 Build
philgresty
SOHC Associate
November 02, 2016, 11:16:15 AM »
youll be fine with that, i ran an 8ah battery in my kick only cb550 running a motogadget m unit and points ignition for a year with no trouble. the dyna ignition is a little more thirsty than points but not much.
Last Edit: November 02, 2016, 11:21:49 AM by philgresty
cantarauk
SOHC Member
November 02, 2016, 04:13:49 PM »
Hi Philgresty,
Thank you for that. Are you running the dyne ignition now and if so the 3 or the 5 Ohm version ?
Glenn
'72 500 Build
philgresty
SOHC Associate
November 03, 2016, 08:47:38 AM »
Hey, i dont, my brother has dyna and a motogadget setup on his, as far as i know, the 3ohm is needed for the dyna s igntion, and the 5ohm is for standard points ignition
Other Stuff
Tricks & Tips
