Author Topic: Jis screwdrivers  (Read 14768 times)
Offline Colonial-Clive (yindi)
  • Colonial_clive
Jis screwdrivers
« on: November 16, 2016, 02:52:22 PM »
Hi guys and gals found this site today for JIS screwdrivers that fit the old cross heads, no more chewed screws.
http://ruggedroads.co.uk/epages/00cbb604-5d1c-407e-8207-580e14387ec5.sf/en_GB/?ObjectPath=/Shops/00cbb604-5d1c-407e-8207-580e14387ec5/Products/%2212705/6/8%22
Offline Seabeowner
Re: Jis screwdrivers
« Reply #1 on: November 16, 2016, 03:15:16 PM »
They is also an impact version that is out of stock atm. But available elsewhere. Has anyone used one of these?
http://ruggedroads.co.uk/epages/00cbb604-5d1c-407e-8207-580e14387ec5.sf/en_GB/?ObjectPath=/Shops/00cbb604-5d1c-407e-8207-580e14387ec5/Products/125961
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #2 on: November 16, 2016, 03:54:30 PM »
Yes to the above and they're absolutely superb tools.
« Reply #3 on: November 16, 2016, 08:08:53 PM »
I have spent thousands on tool over the years and have found these JIS tools a rip off. Most people are shocked that I still use PH1, 2 and 3 and find they do the same job, even on the end of a torque wrench.
Even Ash had to agree with me that the PH is a very good fit.
The only time I have trouble getting a JIS machine screw out is when someone else has had a go before me.
And bloody cheap >>> http://www.ebay.co.uk/itm/10-x-Screwdriver-Screw-Bits-25mm-S2-Grade-Steel-1-4-inch-Various-Types-/181247177367?var=&hash=item2a332c7297:m:mKYZ1QBnqZ27KWZ-3ulcVtQ
« Reply #4 on: November 16, 2016, 08:12:50 PM »
I agree Trig, I would add that a PH2 fits better with the tip ground off a tadge.
« Reply #5 on: November 16, 2016, 08:34:47 PM »
Isn't that what a grinder is for ?  ;D
« Reply #6 on: November 16, 2016, 08:43:12 PM »
  NOW this made me chuckle !!!!!
« Reply #7 on: November 16, 2016, 09:31:49 PM »
Am I missing something?   Tried all the double entendres... Nothing.
« Reply #8 on: November 16, 2016, 09:40:05 PM »
No Mike, he did just mean a grinder, your trying to read something into what's not there  ;D ;D ;D
« Reply #9 on: November 16, 2016, 10:28:45 PM »
It's been a long day...
Offline onethumb
« Reply #10 on: November 17, 2016, 01:12:51 PM »
  Is that "a grinder" or just "grinder" because that changes the whole context about what shape fits best.
Offline kevski
« Reply #11 on: November 24, 2016, 07:52:01 PM »
Bought a set of these last week and they are a far better fit than any phillips screwdriver, even the ones with the ground tip i have been using for years, so now my ruined phillips ones will be consigned to the bin.
« Reply #12 on: November 25, 2016, 02:04:54 PM »
Like to see how you fit those screwdriver on a torque wrench.
Offline kevski
« Reply #13 on: November 25, 2016, 09:39:35 PM »
Never used a JLS screwdriver in my life, like Trig a PH2 ground down on the tip worked just fine. I also found the Snap-On PH2 socket worked really well, although I did break the tip on a few of them using an impact driver with them, free replacement and they never asked how I'd broke it  :)
This is where you are getting wrong, If you try jis and not jls you will find there is a difference🙂
Offline kevski
« Reply #14 on: November 25, 2016, 09:43:32 PM »
A ph2 will never fit a jis screw better than a jis screwdriver no matter how much hope you put into it.
« Last Edit: November 26, 2016, 06:25:37 AM by kevski »
