Author Topic: Jis screwdrivers  (Read 14767 times)
Re: Jis screwdrivers
« Reply #15 on: November 25, 2016, 02:04:54 PM »
Like to see how you fit those screwdriver on a torque wrench.
Offline kevski
« Reply #16 on: November 25, 2016, 09:39:35 PM »
Never used a JLS screwdriver in my life, like Trig a PH2 ground down on the tip worked just fine. I also found the Snap-On PH2 socket worked really well, although I did break the tip on a few of them using an impact driver with them, free replacement and they never asked how I'd broke it  :)
This is where you are getting wrong, If you try jis and not jls you will find there is a difference🙂
Offline kevski
« Reply #17 on: November 25, 2016, 09:43:32 PM »
I agree Trig, I would add that a PH2 fits better with the tip ground off a tadge.
A ph2 will never fit a jis screw better than a jis screwdriver no matter how much hope you put into it.
« Last Edit: November 26, 2016, 06:25:37 AM by kevski »
Offline tom400f
« Reply #18 on: November 26, 2016, 10:09:33 AM »
This is worse than oil  ::)
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
« Reply #19 on: November 26, 2016, 12:24:40 PM »
:-) I like to precision grid an Ingot of Unicorn shyte to my own unique interpretation of the JIS standard. Then send my engines to Graham to rebuild. Simple.
Offline RGP750
« Reply #20 on: November 26, 2016, 12:43:43 PM »
Well that's one way to kill a "no win" conversation ;D ;D ;D
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
« Reply #21 on: November 26, 2016, 02:51:04 PM »
Ha ha was quite enjoying the conversation.
Offline steff750
  • THE POWER OF DREAMS
« Reply #22 on: November 26, 2016, 07:54:46 PM »
Quote
:) so was i? who kicked the ball in the long grass
so to add fuel to the fire i just undone a 17 mm tappet cover by hammering a 16mm open ended spanner on it lol
that says a lot about  JIS tools init
Japanese Industrial Standard means nothing in my garage  ;)
« Reply #23 on: November 26, 2016, 08:19:06 PM »
Why are tappet covers so, so tight. It is only two full turn thread and with a O ring. I had one once that it didn't matter how much heat, metrinch socket on a breaker bar, it would not budge. Ended up drilling it out, maybe should of tried a JIS Screwdriver on it first  ;D ;D
« Reply #24 on: November 26, 2016, 08:23:37 PM »
Maybe a JIS screwdriver would have removed the seized centre stand pivot easily.  ;D
« Reply #25 on: November 26, 2016, 08:28:55 PM »
See, that is where you were going wrong ;D
« Reply #26 on: November 27, 2016, 11:05:07 AM »
My oil gallery plug will only loosen if I hammer a 1/4" whitworth socket over the end. Maybe because it's plumbing.
« Reply #27 on: November 27, 2016, 04:15:31 PM »
Try using a JIS screwdriver.  ;D ;D
