Project Board
CB466f
7
8
9
10
Topic: CB466f (Read 62401 times)
Erwin83
SOHC Member
Re: CB350f (466 big bore) - she runs!
Reply #105 on:
March 08, 2020, 04:42:10 PM »
Thanks everyone. “Understated cafe styleâ€, if I would have had a goal at the start of the project(s), this would have been a nice statement to put it. I like that, thanks for the compliment.
CB466f - KTM 1190 advR
Rob62
ZZR1100D9, CB750K4, RD250F, NSR250MC21, RD350YPVS
Reply #106 on:
March 11, 2020, 07:33:11 PM »
Like it a lot! That seat really sets it off...very retro
Erwin83
SOHC Member
Reply #107 on:
March 31, 2020, 08:54:55 AM »
My other project is also getting along nicely:
Erwin83
SOHC Member
Reply #108 on:
April 01, 2020, 07:59:23 AM »
Needs some 2K, but all color is on
Erwin83
SOHC Member
Reply #109 on:
April 23, 2020, 08:56:09 PM »
Erwin83
SOHC Member
Reply #110 on:
May 12, 2020, 08:30:37 PM »
Update of the "yellow one". Seat done, headlight done. Basically just the engine left to do and button up.
Erwin83
SOHC Member
Reply #111 on:
August 03, 2020, 09:51:22 PM »
Finally some progress on the yellow 350f, after I broke two oil rings while trying to install the cylinders, I had to order new rings from cruzinimage and stuff like that sets you back a couple of weeks.
This time I was more careful and the engine is now coming together.
Those 400 headers look so sexy
Last Edit: August 03, 2020, 09:53:11 PM by Erwin83
Erwin83
SOHC Member
Re: 2 x CB350f Black 466cc cafe-style & yellow 350 tracker-style
Reply #112 on:
August 06, 2020, 10:35:11 AM »
Not finished, but it's getting there:
Rob62
Reply #113 on:
August 06, 2020, 01:16:53 PM »
Nice...
Erwin83
SOHC Member
Reply #114 on:
September 14, 2020, 11:46:01 AM »
Updates!
The black CB466f is smoke free since I changed the headgasket. I'm still treating here carefully as I will be doing a head re-torque after 500km of gentle riding.
Synched the carbs, and she's running like a sewing machine. Albeit a noisy one, with those 4 open pipes.
The yellow one is also getting close to being road-worthy. I had 2 test rides now, leading to altering the carbs (needle 1 position lower, I had it at max rich).
I also found that I have no battery charging during riding, there is no power to the white wire out of the reg-rec, which I guess means that my generator is not magnetized and therefore not working at all. It's a cheap reg-rec combo, I figure it's a DOA.
I also ordered a new silencer, so visually the bike is going to be finished soon.
Erwin83
SOHC Member
Reply #115 on:
September 14, 2020, 01:33:31 PM »
Did a little test: I had another old fashioned regulator laying around. So I unplugged the black and white from the new R/R combo, but let the 5 pin connector installed (using the R/R combo purely as a rectifier) and connected the old regulator.
Presto! I have charging power now. So the R/R combo must have some problem inside with the rectifier.
Bummer.
Is there any harm in riding with a R/R combo with the regulator unplugged, and using an old fashioned regulator instead?
I have no idea of the inner workings of a combined R/R.
Reply #116 on:
September 14, 2020, 11:25:43 PM »
As long as the loose terminals are insulated just in case it decides to play silly it should be ok
Erwin83
SOHC Member
Reply #117 on:
September 16, 2020, 04:45:03 PM »
Got the new silencer installed
A silencer that actually silences! Unbelievable for <40 GBP (
https://www.classicbikeshop.co.uk/short-daytona-36mm-44mm.html
That means that this project is visually finished. Only some technical stuff to fix or improve:
- Carb jetting (main 90 now, seems rich) and need a synch.
- oil leak from the left side of the engine. Looks to be the O-ring of the oil gallery plug.
- Drive chain
- Longer jiffy (anyone know a plug-and-play option that is 1-2 inch longer?
- replace the R/R unit
Last Edit: September 16, 2020, 04:48:29 PM by Erwin83
SumpMagnet
Reply #118 on:
September 17, 2020, 06:47:42 PM »
Nice.
It's not really my style of bike, but I can still appreciate what's been done. The modern front end sits well and doesn't look out of place, which they often can do.
The swoopy 400-4 pipes and a short mega suit the style too.
It's clean, simple, and looks like a flat tracker.
Job done, and done well
CB750F2 - in pieces
Erwin83
SOHC Member
Reply #119 on:
September 18, 2020, 07:11:49 AM »
Thanks!
7
8
9
10
Project Board
CB466f
