CB750
750 F2 - Seized or awkward brake master cylinder?
Topic: 750 F2 - Seized or awkward brake master cylinder? (Read 4208 times)
Drew400
400/4 I restored
January 04, 2017, 07:11:21 PM »
Hi experts,
I have decided to refurbish my rear brake master cylinder. However, having removed the awkwardly stuck circlip, I can't get inside it.
As you can see from the picture below, the circlip is out. I’m guessing (from the exploded parts diagram) that the 'this bit' marked in the picture should ease out (under pressure from the spring behind it?) and is only held in place by the circlip. However, it's not moving after some very gentle persuasion and WD40 soaking.
Any hints or tips on how to progress or explanations about what I’m doing wrong?
Thank you,
D.
Re: 750 F2 - Seized or awkward brake master cylinder?
January 05, 2017, 07:37:48 AM »
gentle application of heat
Drew400
400/4 I restored
January 05, 2017, 08:38:22 AM »
Thanks Bryan, will do.
onethumb
SOHC Expert
January 05, 2017, 05:36:39 PM »
Had the same problem as you. I got through it by wire brushing it then soaking it in wd40, putting a nut on the thread then putting that in the vice and using a bit of heat from a bit of a distance as bryanj said and moving it back and forth till it freed up. Took about 5 minutes.
Good luck.
Drew400
400/4 I restored
January 05, 2017, 06:01:41 PM »
Thanks Onethumb,
I have now succeeded. It was as you both described: scrape away the old crap that gathers in there; leave soaking in WD40 overnight; dry and have another scrape; hold in the vice (gently); warm up with by butane burner(not too hot); then I used a claw hammer to lever gently in the plunger. It came away really easily, so hardly any leverage needed (thankfully).
Now for the next stage...
Cheers both,
D.
January 06, 2017, 12:19:38 PM »
Next stage is finding a seal kit then taking out the mortgage to buy it!! Don't think anybody does aftermarket for those
hairygit
January 06, 2017, 12:22:57 PM »
CMS has genuine in stock, 55 euros though!
January 06, 2017, 12:23:50 PM »
Plus postage as well
hairygit
January 06, 2017, 12:32:05 PM »
Okay Bryan! But we did the first bit, found them! Now you need to decide, sell a kidney or re mortgage the house!
January 06, 2017, 01:56:26 PM »
CB750FA (77) 750 SUPER SPORT, JPN, VIN# CB750F-2100011 TO CB750F-2111489
CB750FA (78) 750 SUPER SPORT, JPN, VIN# CB750F-2200001
GL1000A (78) GOLD WING, JPN, VIN# GL1-4000001
GL1000A (79) GOLD WING, JPN, VIN# GL1-4100003
43530-410-305 £42 at Dave Silver but out of stock, worth trying your local dealer as most of them deal with a big firm Leeds way(cant remember the name, maybe Hi Level)) and the have a huge catalogue you look up by bike, I got a pack of 5 caliper seals for a 1200 wing for less than the price of 1 honda but only by cross refering the sizes
Last Edit: January 06, 2017, 02:02:15 PM by Bryanj
Drew400
400/4 I restored
Reply #10 on:
January 06, 2017, 04:16:06 PM »
Thanks all.
Mine was ordered (43530-410-305 from DSS) before I started the work and is sitting next to me as I type, pending the next phase, installation.
Maybe my order emptied the stock... apologies to anyone else out there needing one in a hurry!
D.
onethumb
SOHC Expert
Reply #11 on:
January 06, 2017, 08:24:57 PM »
I'm hoping mine is ok. It looked fine when I stripped it and at the price they are I thought I'd take a punt. Nothing to loose.
Haven't put any fluid in it yet though.
Drew400
400/4 I restored
Reply #12 on:
January 06, 2017, 10:41:00 PM »
Fingers crossed for you.
Cheers,
D.
CB750
