SOHC.co.uk Forums > CB750
Can't removal rotor
Yurkie:
I might have to follow in you footsteps of going to a local bike shop. Tried heat with both a three leg puller and also the single bolt. Neither are looking to good now. Just need to find a single bolt puller with a nut head rather than the T bar which I have now bent. Then purchase an impact wrench. If that fails I need to look for a friendly bike shop.
Seabeowner:
On the 500/550 the thread is M16 x 1.5 I think. I used a fiat van wheel bolt bought on ebay for £1.50 and turned a couple of threads off so that it pushed evenly on the end of the crankshaft. Used 4 times with no problem. Heat with hand held electric gun, tighten really hard, whack with aluminium headed mallet, tighten again, and whack again.
mike the bike:
Isn't that the same thread as the oil filter bolt?
Drew400:
One further thought from a rank amateur.... tighten the puller then leave for a few hours, go and do something else then tighten it further again. Repeat. This doesn't work if the job needs doing quickly, but eventually the forces applied will have a bearing on the outcome given enough time!
Yurkie:
Ok I've finally got the puller off. Took the puller tool which had a tommy bar in it a cut a hex on it for a socket, and used a wrench with an extended bar to increase the leverage. Thanks for all the help and suggestions.
Navigation
[0] Message Index
[*] Previous page
Go to full version
