Author Topic: New member  (Read 20247 times)
Offline Tony P
Re: New member
« Reply #45 on: March 24, 2017, 01:59:02 PM »
Afternoon gets
Struggling to remove the carbs, helpful hints excepted !
Many thanks
Re: New member
« Reply #46 on: March 24, 2017, 02:30:51 PM »
Remove all the engine bolts except the two lower ones (just loosen those) ,  remove the exhaust,  jack the engine up so it tilts forward.   That'll give another 20mm to play with.
Offline Tony P
Re: New member
« Reply #47 on: March 24, 2017, 02:36:42 PM »
Thanks Mike
Offline Tony P
Re: New member
« Reply #48 on: March 27, 2017, 02:13:32 PM »
Hi all
Engines out and most of everything else striped, just struggling to remove the front disk, it's on a cast wheel as previous pictures.
Have removed the four retaining  bolts but still no joy !
On another note, found lots of bits of metal in the sump, so not looking forward to the full engine strip !
Will attach som pics later !
Offline Tony P
Re: New member
« Reply #49 on: March 27, 2017, 03:11:26 PM »
Just found " ARE 1978 " stamped on the rear wheel !
