General > New Member Introductions
New member
<< < (10/10)
Tony P:
Afternoon gets
Struggling to remove the carbs, helpful hints excepted !
Many thanks
mike the bike:
Remove all the engine bolts except the two lower ones (just loosen those) ,  remove the exhaust,  jack the engine up so it tilts forward.   That'll give another 20mm to play with.
Tony P:
Thanks Mike
Tony P:
Hi all
Engines out and most of everything else striped, just struggling to remove the front disk, it's on a cast wheel as previous pictures.
Have removed the four retaining  bolts but still no joy !
On another note, found lots of bits of metal in the sump, so not looking forward to the full engine strip !
Will attach som pics later !
Tony P:
Just found " ARE 1978 " stamped on the rear wheel !
Navigation
[0] Message Index
[*] Previous page
Go to full version
