Other Stuff
Tricks & Tips
Grease is the word
Topic: Grease is the word (Read 10734 times)
hairygit
Re: Grease is the word
Reply #15 on:
April 26, 2017, 02:54:15 PM »
Yes you can, that's what Bryan was saying, but the but nut would end up on the wrong side. If you use a piece of bar to tap the pivot out, sort the grease nipples, the n use the pivot to tap the bar out, you can put it back the right way round.
MrDavo
Reply #16 on:
April 26, 2017, 03:45:59 PM »
Ah, now I get what he meant, stupid me.
I see the nipple fits many different Hondas and is available from the US, not that dear so no duty hassles etc. I take Bryan's point about a hollow drift (I could always drill a suitable blind hole in something), how hard is it to get them out without snapping them or leaving something behind though?
petermigreen
Reply #17 on:
April 26, 2017, 04:05:38 PM »
Just did mine at the weekend.
Pulled out easily enough gripped wit a pair of pliers, then knocked the new ones home using a small 6mm socket from a small 1/4 drive set.
Nipples came from dss
Peter
Last Edit: April 26, 2017, 04:07:58 PM by petermigreen
MrDavo
Reply #18 on:
April 26, 2017, 04:29:12 PM »
DSS had none (Coz Peter bought them all) but I managed to order a pair online from Fowlers, never tried them before, but it saves the stupid delivery charge & wait from USA.
petermigreen
Reply #19 on:
April 26, 2017, 05:00:33 PM »
You snooze you loose....
Sorry about that.
Peter
Reply #20 on:
April 27, 2017, 07:25:11 AM »
Its never been a problem getting the old ones out but i have seen a lot damaged on re fitting as a lot of sockets get small too soon and peen over the ball in the outside if you see what i mean. Don't worry me just let me know if you want a modded one as i only do them when neded
MrDavo
Reply #21 on:
April 29, 2017, 06:41:46 PM »
Mission successful! Old nipples pulled out with mole grips, new ones tapped in using a deep 7mm socket. Once I started pumping grease in I could hear things going on inside the swinging arm.
I was surprised how much back pressure there was once it was full, but I think the bushes and pin may be new, there is zero play.
At least now I can give it a squirt every 1000 miles or so and avoid uneccesarily wearing the bushes out. Yet agin, thanks for all your help.
Other Stuff
Tricks & Tips
Grease is the word
