Author Topic: Indicator lens cover  (Read 5985 times)
Offline ted_paper
« on: April 23, 2017, 07:00:28 PM »
Hi All, just found out when trying to replace damaged cover that the front indicator lens cover is slightly smaller diameter than the rear one on my '77 CB400. The new cover is advertised as fitting my bike so I'm wondering if this is this normal or has one been replaced at some stage and if so what is the correct diameter?
Re: Indicator lens cover
« Reply #1 on: April 23, 2017, 07:10:15 PM »
They should be the same size front and rear. give me 5 mins and I will measure mine.
« Reply #2 on: April 23, 2017, 07:13:51 PM »
Original Stanley's 720mm OD
Offline ted_paper
« Reply #3 on: April 23, 2017, 07:21:54 PM »
Thanks Nurse Julie -  (BTW I  assume you mean 72mm - 720mm is  bigger than my dustbin lid  ;))
« Reply #4 on: April 23, 2017, 07:24:06 PM »
Hehe, sorry about that  :-[ :-[ Yes, 72mm
Offline kent400
« Reply #5 on: April 23, 2017, 07:46:45 PM »
Sounds like either the lens you have isn't genuine Stanley or the lamp isn't. The genuine lens will be marked Stanley and if I remember correctly a genuine lamp is marked Stanley on the inside.
« Reply #6 on: April 23, 2017, 07:52:20 PM »
Are you coming up with a different size than me Peter ?. My CB 400/4 measure 72mm and has original marked Stanley lenses and original marked Stanley lamps. Also, all the other bikes we have here with original Stanley measure the same
« Last Edit: April 23, 2017, 07:55:53 PM by Nurse Julie »
« Reply #7 on: April 23, 2017, 07:57:02 PM »
  How did you NOT kill a patient making errors like that, doctor says 10mg morphine, god knows what they'd actually get from you! :o :o :o ;D ;D ;D
« Reply #8 on: April 23, 2017, 07:59:20 PM »
Worry not Hairy, I NEVER got a drug calculation wrong. It was a typo on my part, trying to dish up dinner at the same time
Offline ted_paper
« Reply #9 on: April 23, 2017, 08:00:19 PM »
I've tried to measure mine and I'm getting around 65mm internal dia. They aren't marked Stanley so it looks like they are replacements.
Does anyone know which model/make might fit mine?
« Reply #10 on: April 23, 2017, 08:03:03 PM »
Not sure to be honest. I have just taken lenses of original K6 and K2 and they still measure 72mm
« Reply #11 on: April 23, 2017, 08:05:35 PM »
Most Honda fours up to 1977, but NOT 550K3, 750F2 or K7
Offline kent400
« Reply #12 on: April 24, 2017, 08:38:52 AM »
As Julie stated the original Stanley lens is 72mm, the one fitted to the replica lamp is 70mm. Both the original Stanley and the replica lamps are shown in the image. The original is the one on the left. Cleanly the lenses are not interchangeable
« Reply #13 on: April 24, 2017, 09:43:12 AM »
FYI, that phillips screw is where I attach the extra earth lead to connect it to the wiring loom.  Makes for a more reliable flash.
Offline Seabeowner
« Reply #14 on: April 24, 2017, 01:24:30 PM »
I've bought 6 of these recently and although good value IMHO the lens locations are about 0.5mm smaller and not easily interchanged with vintage ones. The lenses are marked 6.0345. And they are two wire so no worries on grounding.
http://www.ebay.co.uk/itm/Stanley-HONDA-Motorcycle-Indicators-Chrome-Plated-Steel-Bodied-Suit-Early-Models-/151242755424?hash=item2336c54d60:g:MPcAAOSwEzxYVAid
Or £45 for 4.
But expensive if all you want is a lens.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
