SOHC.co.uk Forums > CB350/400
CB400F carb. leakage
Nurse Julie:
As long as the carb plate is removed, you can just pull the carbs apart at the 'T' piece.
MikeSB6:
Hello,
thanks Julie, I'll give it a whizz,
Cheers, MikeJ
mike the bike:
You need to undo the 8 countersunk M5 screws that secure to carbs to the plate like wot Mike J said
01thomas:
Blocked carb float bowl vents (in the roof of the float chamber) will also cause a high fuel level in the float bowls and for that fuel to leak out everywhere.
MikeSB6:
Hello,
thanks for all the replies, I've now separated the carbs from the frame and replaced the O-rings but they're still leaking - maybe I've used the wrong size? Are they imperial? I'll blow through the upper vents to check them, too,
Cheers, MikeJ
Navigation
[0] Message Index
[*] Previous page
Go to full version
