CB750
HEAD GASKET
Topic: HEAD GASKET (Read 4097 times)
captaink
Old racers never die. ' they just go faster '
SOHC Expert
HEAD GASKET
May 30, 2017, 04:47:18 PM »
Hi, Any thoughts on the following appreciated.
I'm in the process of building a 1977 k7 engine and its now got a Wiseco 836cc big bore kit fitted.
The Cometic head gasket that came with the Wiseco kit only has two larger (17mm ) hole cut outs for the studs with O rings the rest are just stud clearance size.
My cylinder has the 2 plus 8 more for the knock pins and seals, 10 X 17MM holes are required in total.
The Wiseco kit supplier says there's only ever been this gasket which is wrong for me.
The standard gasket kit from Silvers has all 10 larger holes but of course the cylinder bore size is standard 750cc and too small.
I have seen gaskets on USA sights but wondered if anyone has had this issue and know a UK supplier ?
Regards Keith
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International 1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
adriangsmith
SOHC Member
Re: HEAD GASKET
May 31, 2017, 12:19:56 PM »
I had the same issue recently.
I ended up drilling the clearance holes out very carefully as whoever had bulit the engine before me had fitted as standard and squashed all the rubbers underneath the gasket. no wonder it leaked before!
To drill out get 2 plates of aluminum made up with a 17mm hole drilled through and bolted together at both ends. place gasket in between line up the hole in the gasket you need to enlarge and drill through.
Remove any burrs from around the hole and hey presto. sorted.
Just need a bit of bravado and belief to drill into a £50 head gasket!
Triumph Thruxton 2004
Honda CB750F1 1976
Honda CB400F 1976 (current project)
captaink
SOHC Expert
Re: HEAD GASKET
June 13, 2017, 09:34:03 PM »
Enquiries about the head gasket are on going but it appears I can get the correct gasket from japspares in Australia, its a Forsetti gasket.
836cc big bore kit 65mm bore with 10 in total larger 17mm clearance holes
Anyone know anywhere nearing than the opposite side of the planet ?
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
captaink
SOHC Expert
Re: HEAD GASKET
June 16, 2017, 04:14:49 PM »
Thinking on this subject What about this as an option to solve the problem....Any thoughts
The 8 larger holes in the cylinder barrel as fitted with later engines are an upgrade to early engines and require knock pins ( sleeves ) and a rubber seal.
Why cant I make 8 small spacers that accurately fit in the larger holes, flush with the head thereby reverting back to the earlier models ?
Does this make sense as although an upgrade from about 1975 there's a lot of engines out there pre 1975.
I could then use the Cometic gasket with the smaller holes.
Thoughts ?
Regards Keith
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
K2-K6
Re: HEAD GASKET
June 16, 2017, 04:24:50 PM »
It's relatively easy to make a basic punch and die set to re-cut the gasket holes to the right size which would possibly be easier.
We used to make them specifically to cut gaskets as apprentices, if you want more info it may be worth a chat to explain as it could be quicker and more consice than me typing it.
I'll pm you my number if you want it.
captaink
SOHC Expert
Re: HEAD GASKET
June 16, 2017, 05:31:19 PM »
Hi, I did order a 17 punch and it did work ( I hope )
I did this for my other cb750 I'm building but the 17mm holes are so close to the main fire ring it's worrying.
The Cometic gaskets as most contain metal and the punch soon loses sharpness.
Lets say it wasn't as good as I wanted but we'll see.
I can get a Forsetti gasket from Australia.
Options many !
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
K2-K6
Re: HEAD GASKET
June 16, 2017, 06:06:19 PM »
We'd make them out of two 1/2 inch steel plates that where dowelled for location then bored and reem the punch hole to desired size through both plates, then make a punch out of silver steel with concave curve to the face. This was heat treated to harden the cutting edge and hand ground (sounds like a waitrose food advert) to get the edge sharp.
It would cut gasket material and metal shim of copper, brass and steel with a very clean unburred edge and no distortion. The work material was clamped in between the die plates and with a hefty wallop, the punch would got straight through.
Re: HEAD GASKET
June 16, 2017, 11:14:41 PM »
I foresee no engineering problem with small spacers, except the original oil leaks that the seals were supposed to cure, as long as the adaptors are sealed in the holes BUT be careful with which cylinders you use as the later ones (F2 I think) had a different oil return path
westfieldandy
Newbie
Re: HEAD GASKET
July 17, 2017, 02:53:07 PM »
I use the supplied gasket with the 836 kits from weiseco, they all have the small hole which is a pain. I machine up a punch to recut the holes in a fly press.
works ok, but just time consuming.
Andy
www.good-bits.co.uk
CB750
HEAD GASKET
