Author Topic: Back wheel locked up  (Read 3296 times)
Offline yozzer74
« on: June 22, 2017, 11:03:12 PM »
Went out on bike today just riding through local village and back wheel locked up then freed off then locked up again . Thought something had gone in gear box . But found this pics below i [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Offline yozzer74
Re: Back wheel locked up
« Reply #1 on: June 22, 2017, 11:05:23 PM »
Offline yozzer74
« Reply #2 on: June 22, 2017, 11:07:51 PM »
Never seen that before just my luck lol . Had no tools on me so had to call recovery out . He said never seen that before
« Reply #3 on: June 22, 2017, 11:11:45 PM »
Bloody hell Yoz - you've had some bad luck with your bike since the rebuild!
« Reply #4 on: June 22, 2017, 11:12:15 PM »
Wow, what is that stuck in the chain?
I can't make out the context of the second picture, struggling to place where it is.
Bet that was scary!
Offline yozzer74
« Reply #5 on: June 22, 2017, 11:35:45 PM »
Second picture is the cover that goes over front sprocket and it's a 6 mm nut that's stuck in chain.
« Reply #6 on: June 23, 2017, 06:03:39 AM »
The lock up would be when the nut forced the chain off the front sprocket into that cracked cover, luckily there should be loads of those covers about, just hope no damage behind it
« Reply #7 on: June 23, 2017, 07:57:59 AM »
Crikey, lucky you were just in the village and not on a motorway. Where did that nut come from?
« Reply #8 on: June 24, 2017, 06:51:25 PM »
Bad luck .. as long as you are OK though.
I have a spare cover .. a bit moth eaten on one edge but if yours is painted it would probably be fine. If you want it I can picture. Just pay postage.
Offline MarkCR750
« Reply #9 on: June 24, 2017, 09:31:31 PM »
Sounds like you had a lucky escape there Yozzer!, good job you weren't on a bend at speed, I've never heard of that happening before to anyone, I'll check my nuts for tightness (so to speak) tomorrow.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
« Reply #10 on: June 25, 2017, 05:39:33 PM »
I think an event like that would make sure anyone's nuts were properly tight  ;D along with a few other parts as the anatomy as well!
Yozzer,  was it a nut that fell off your bike or something kicked up from the road?
Offline yozzer74
« Reply #11 on: June 29, 2017, 10:34:06 PM »
It looks like one off my bike but I can't see we're from .unless it's one I've lost on bike when I've been working on it ??
« Reply #12 on: June 30, 2017, 07:53:27 AM »
Blimey,  could have been a lot worse.  Best spend half an hour with the spanners checking everything.   On a big rebuild job it's easy to overlook something.
My oil pump cover were a bit loose which leaked oil but could have come off on a long trip dumping all my oil on the M5.
See you Sunday.
« Reply #13 on: June 30, 2017, 08:24:08 AM »
It would be unusual for something like that to stay around long if you'd just dropped it in the past, also to get to the inside run of the chain.
Can't remember what chaingaurd you've got on it, could it be anything from there?
Offline yozzer74
« Reply #14 on: June 30, 2017, 04:56:38 PM »
No I haven't got a chain guard on it
