CB750
re-jetting needed?
3
6
Topic: re-jetting needed? (Read 23895 times)
El__burro
SOHC Expert
re-jetting needed?
June 22, 2017, 11:54:51 PM »
good day,
I have been riding my cb750 k2 for over a month and today I went back to ride my Bmw r80/7 and
i have noticed a huge difference in maximum speed and overall performance.
my cb750 is definitely slower.
i have synced the carbs but not fully understood how to set the air mixture the same for all 4.
also I have replaced the standard air filter for K&H (like) stacks and gone to a 4-2 exhaust system but kept the stock jets..
would i see any difference in changing their size.
if yes, what size?
el__burro
hairygit
Re: re-jetting needed?
June 23, 2017, 05:52:26 AM »
Yes, increasing the jet size is necessary running stack or pod filters. As they are more free flowing than a stock filter set up the decreased resistance means it pulls less fuel through the jets, and gives a weaker mixture. Every bike will behave differently to given changes, so it's trial and error until it runs as best as it can with the filter/exhaust combination. What size jets are you currently running?
El__burro
SOHC Expert
June 23, 2017, 06:55:34 PM »
The actual jet are 110.
Since i have both pods and 4-2 exhaust system, shall i go 4 up?
Where shall i buy them?
el__burro
Sent from my SM-G935F using Tapatalk
Last Edit: June 23, 2017, 06:57:42 PM by El__burro
El__burro
SOHC Expert
June 23, 2017, 07:22:32 PM »
Actually I have just found this..
Shall i go +6 then?
el__burro
hairygit
June 23, 2017, 08:01:58 PM »
A U.K. K2 should have 115 as stock, so you're way too small at the moment!
El__burro
SOHC Expert
June 23, 2017, 08:56:46 PM »
The bike comes from Italy.
Should I go 4 or 6 up?
el__burro
hairygit
June 23, 2017, 10:03:22 PM »
Try 4, then you've still got the needles to give you play either side. How has it been riding up to now? Does it feel starved of oomph?
El__burro
SOHC Expert
June 23, 2017, 10:12:01 PM »
It rides fine, I have tried to go very fast but as I said its much less responsive than my other bike. (Bmw r80)
Would reJetting make any difference?
el__burro
El__burro
SOHC Expert
June 25, 2017, 12:35:00 AM »
Not sure what size to look for and where. Any suggestions?
el__burro
June 25, 2017, 01:28:18 AM »
Sirius in canada do jet kits or individual jets
El__burro
SOHC Expert
Reply #10 on:
June 25, 2017, 10:10:36 AM »
Woaw.. are you sirius.. in Canada?
What size should I go for?
el__burro
Reply #11 on:
June 25, 2017, 12:35:40 PM »
Best card parts supplier I have found in 30+ years and no idea on jet size
totty
SOHC Expert
Reply #12 on:
June 25, 2017, 01:13:30 PM »
Looks like you're going to have to do this by trial and error, so you probably need to order both +4 and +6. After finding best full throttle performance you'll them more than likely need to adjust needle height, then pilot adjuster and maybe even pilot jet. A lot of work on a four.
I don't know which jets this model uses, but I got my last jets from wemoto and I've also used allensperformance.
philward
Reply #13 on:
June 25, 2017, 08:42:44 PM »
I've used Allens too -
http://www.allensperformance.co.uk/carb-kit/keihin-jet-identification-chart/
El__burro
SOHC Expert
Reply #14 on:
June 25, 2017, 08:52:00 PM »
Thanks Phil, I've been looking for jets on both wemoto and allens..
What jets would i need from the link above..?
Thanks a lot
el__burro
3
6
CB750
re-jetting needed?
