Author Topic: What's this bit??  (Read 2536 times)
Offline Blasta
What's this bit??
« on: August 28, 2017, 07:26:38 AM »
What's the electrical component that is just behind the headlight and below the speedo? It's mounted on the top of the left fork leg.
You might be able to see it in this pic. Thanks.
Re: What's this bit??
« Reply #1 on: August 28, 2017, 07:45:30 AM »
Indicator buzzzzer  ;)
« Reply #2 on: August 28, 2017, 07:49:52 AM »
Can't actually see what you're referring to, but it is probably a turn signal buzzer, if it is it will have 2 wires connected to it, and many owners disconnect them!
Offline Blasta
« Reply #3 on: August 28, 2017, 07:50:18 AM »
Really? There is no buzzing when the indicators  are on.
Offline Blasta
« Reply #4 on: August 28, 2017, 07:51:15 AM »
It does have wires connected to it that go into the back of the headlight.
« Reply #5 on: August 28, 2017, 07:53:01 AM »
Maybe it doesn't work anymore.
Offline Blasta
« Reply #6 on: August 28, 2017, 07:59:59 AM »
I think you might be right. Thanks for your help :)
Online Bryanj
« Reply #7 on: August 28, 2017, 11:30:13 AM »
Honda requested dealers to disconnect them at PDI as it was thought that the noise was similar to pelican crossings and might confuse the blind. We all thought it was different and asked the purchasers if they wanted it or not
« Reply #8 on: August 28, 2017, 05:42:26 PM »
I disconnected and removed mine within days of buying my F1 in 76, It's still floating around in the garage somewhere.
Offline Blasta
« Reply #9 on: August 28, 2017, 10:38:56 PM »
I think I'll remove it too. Thanks for your comments.
