Author Topic: Bike lift  (Read 7750 times)
Offline yozzer74
Bike lift
« on: September 10, 2017, 09:58:38 PM »
Hi thinking of buying a bike lift does anyone have any recommendations  for a good one thanks .
Offline Moorey
Re: Bike lift
« Reply #1 on: September 10, 2017, 10:29:29 PM »
The best birthday present I ever got. You will wonder why you didn't get one years ago. Try to get one with a top wider than 600mm if I put bikes on using the side stand the side stand foot is overhanging the edge of the bench platform.
Re: Bike lift
« Reply #2 on: September 10, 2017, 10:30:48 PM »
Lift or ramp ?
Offline yozzer74
Re: Bike lift
« Reply #3 on: September 10, 2017, 10:31:10 PM »
Ok will look out for that .I'm just sick of lying on floor lol
Offline yozzer74
Re: Bike lift
« Reply #4 on: September 10, 2017, 10:32:06 PM »
Trigger what's the difference
Re: Bike lift
« Reply #5 on: September 10, 2017, 11:10:44 PM »
To me this is a bike lift >>> http://www.ebay.co.uk/itm/Compact-Motorcycle-Lift-Stand-Heavy-Duty-680Kg-Hydraulic-Lifting-Bike-Service-/222638870993?hash=item33d64f91d1:g:uIkAAOSw5ulZsrp~
A ramp needs to be 600 as moorey stated and heavy duty, lots of cheap ones about that are only fit for light weight bikes/scooters.
Offline yozzer74
Re: Bike lift
« Reply #6 on: September 10, 2017, 11:12:37 PM »
It's a ramp I'm looking for then
Offline Moorey
Re: Bike lift
« Reply #7 on: September 11, 2017, 12:00:17 AM »
This is very similar to mine but 60mm wider which will make a big difference as far as the side stands are concerned and also for when you have to stand on them when putting bikes on the main stand.
http://www.ebay.co.uk/itm/Sealey-MC454-Hydraulic-Motorcycle-Lift-450kg-Capacity-/141895475749?epid=1537644240&hash=item2109a12225:g:jlAAAOSwY3BZFOpG
Cheaper ones available.
They do seem to have gone up a bit in price since I got mine 9 years ago. But worth every penny to the knees.
« Last Edit: September 11, 2017, 12:07:26 AM by moorey »
Re: Bike lift
« Reply #8 on: September 11, 2017, 02:11:00 AM »
Don't use bike ramps much, as mostly engine work these days. Have a couple of Clarke CML3's, not the best I have had but strong and 650mm wide.
Re: Bike lift
« Reply #9 on: September 11, 2017, 08:03:35 AM »
Been looking at these lifts for a while. What worries me is the ones on wheels, they look really top heavy when raised. Surely they should be bolted to the floor. I may be wrong as I have never used one that wasn't bolted, but they look like an accident waiting to happen?
Offline Orcade-Ian
    • Older Vehicle Web
Re: Bike lift
« Reply #10 on: September 11, 2017, 08:29:27 AM »
Hi folks,
I have the Sealey type ramp which I bought more than 20 years ago - I think they were all made by Grazia in Italy back then?  I lift a GL1500 GoldWing on it and you would be very surprised how stable it is.  In the early days I deliberately shook hell out of it to see if anything moved and mine is not bolted down but has the 4 screw downs to stop the wheels rolling.
The detachable ramp is far too steep for anything bigger than a C50 but I use a separate, longer braced wooden slope.  Another irritation if you ride the bike up is that you need a platform on the left side to place your foot (and side stand peg) so that you can get off to hoist it on to the main stand.
Good for servicing our ride on mower too.
I also have a Clark Strong arm bike lift which goes under the middle of the Wing and lifts it to a good height for maintenance, including wheel removal.  Also very stable in use.
I used the lift to get the big heavy Getrag 5 speed gearbox out and back in on my XJ-S when I changed the clutch - too old now to balance stuff like that on my chest!!
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Re: Bike lift
« Reply #11 on: September 11, 2017, 09:21:39 AM »
You can take the wheels off and bolt it to the floor but, it has stabiliser bolts so it doesn't move about and while it is on wheel it is easy to move out the way for cleaning and so on.
https://www.tool-net.co.uk/p-345743/clarke-cml3.html?gclid=EAIaIQobChMI89Pdo9ic1gIVTZSyCh01iw5JEAYYASABEgLDz_D_BwE
Offline Rozabikes Tim
Re: Bike lift
« Reply #12 on: September 11, 2017, 09:40:57 AM »
Mine looks exactly like that but isn't Sealey. Screw down stablisers sort it when in desired place. Only issue I have is pivoting front wheels are small diameter and of hard material - so moving even unloaded on concrete that isn't billiard table smooth, is not easy. Also gloss paint finish + any water / fluid on tyre van be an issue if using motor to get bike on ramp. Excellent otherwise.
Offline Orcade-Ian
    • Older Vehicle Web
Re: Bike lift
« Reply #13 on: September 11, 2017, 10:39:07 AM »
Amazon UK have them advertised at £377 inc vat and del at the moment - looks identical to mine and 450 kilos.
Ian
1972 Honda CB 350/4
2026 Honda ADV 350
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
Re: Bike lift
« Reply #14 on: September 11, 2017, 11:22:22 AM »
I've had a Clarke lift for many years with metal wheels (as image), very very heavy to position or move around.
Providing the bike is central on the lift, I have found it very stable
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
