Author Topic: New member South Yorkshire  (Read 2658 times)
Offline Gv8power
« on: September 26, 2017, 01:33:53 PM »
Hi I have a 1975 Honda CB 500 four that has been in the family 30+ years maybe more . It is time to restore the old girl after sitting unused for 12 years
Re: New member South Yorkshire
« Reply #1 on: September 26, 2017, 02:17:38 PM »
Welcome to the forum.   There's loads of people on here only willing to help with the restoration.   A few pics would be good.
« Reply #2 on: September 26, 2017, 04:48:40 PM »
ots of bits about for those but some are very pricey and a few unobtainable, I can do a genuine Honda manual and parts book on cd for not much
Offline Gv8power
« Reply #3 on: September 26, 2017, 06:34:16 PM »
Hi thanks I have the shop manual & Haynes manual . The engine is the main thing doing a full rebuild it's getting there just need to work out main & big end bearings
« Reply #4 on: September 27, 2017, 08:16:36 AM »
Unless they are badly scored you can reuse them saving a lot of time, money and searching as a lot of the shells are not available now
Offline Seabeowner
« Reply #5 on: September 27, 2017, 09:02:53 AM »
Nice to see another 500 joined as I think it's the Goldilocks bike. (not too big, not too small)
I've never replaced any shells, as mostly I've had a running bike. My criteria was always been if the oil light did not come on tickover after a blast to get the engine and oil really hot it was probably OK and provided that was supported by finding no nasty surprises inside, just buttoned it back up. But shells are difficult to find and CMS only have two of the four sizes.
Only needed to strip for primary/cam chains and gearbox issues.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #6 on: September 27, 2017, 09:52:20 AM »
+1 but I would replace the cush drive primary rubbers as a matter of course  (same part no. as 400/4). I remember rebuilding a 400/4 engine when it was less that 10 years old and those rubbers were really hard compared with new ones. Why not post some close up pics of your crank journals and shells and Bryan,Trigger or Oddjob on here will tell you if they look OK to reuse. That's what I did with my 500/4 crank.
« Reply #7 on: September 27, 2017, 10:44:45 AM »
welcome to another 500 owner
 lovely bikes ,small enough to manage,big enough to cope !!
 lots of help here,
 Honda built the 500 after correcting all the mistakes of the 750 !!!
 "ducks ,and hides behind the sofa !! "
« Reply #8 on: September 27, 2017, 11:36:28 AM »
You may well hide John! 750's didn't have the gearbox problems of the 500, nor a dodgy prone to failure clutch pushrod!
« Reply #9 on: September 27, 2017, 01:48:04 PM »
just that /those
 the gear box if fairly major,agreed,but an easily replacable clutch pushrod is very minor !!
  the motor is wet sump,far more compact,even given the capacity ,
 but,truth to tell,all sohc are great pieces of engineering
Offline Moorey
« Reply #10 on: September 27, 2017, 10:29:06 PM »
Welcome . How have you let it sit for 12 years. At least you are putting that right now. Enjoy.👍
