Author Topic: CB400/4 ENGINE STRIP, ASSESSMENT AND REBUILD BY JULIE - NOW COMPLETE  (Read 266851 times)
« Reply #90 on: October 09, 2017, 08:08:54 PM »
yes,she did run well,
Yes John but I couldn't keep up with you  ;D ;D
  well,mine has 65000 on the clock,nicely run in,so spins over well !!!!
So with mine at 47000 miles, do you think I should put my pistons back in for another 1000 miles and see if they bed in any better  ;D ;D ;D ;D ;D
Might need new rings
Offline Green1
« Reply #91 on: October 09, 2017, 08:30:00 PM »
How long have I been away 7 pages in to your rebuild already.
When your finished fancy having a go at mine  ;)
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #92 on: October 09, 2017, 08:38:19 PM »
Thanks for the offer Mick but.......NO  ;D ;D ;D
Offline Green1
« Reply #93 on: October 09, 2017, 08:46:27 PM »
Are you sure I have 2 well uncared for engines with no history and both have stood since 1990.
You should have them done in a week or two  ;D
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #94 on: October 09, 2017, 08:50:41 PM »
Send them up to Trig , with a blank cheque and he will have a look. You may need to find a part time job though to pay the final bill !!! ;D ;D ;D
Offline Woodside
« Reply #95 on: October 09, 2017, 08:59:32 PM »
this thread is gonna break all uk records
Offline Green1
« Reply #96 on: October 09, 2017, 09:00:54 PM »
I don't know about a blank cheque I can send a blank stare  ;D ;D
Time for a part time job would be nice. I fell asleep in the van at lunch time today and woke up with the customer standing next to me about an hour later  :-[
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #97 on: October 09, 2017, 09:05:02 PM »
You could be right there Jason but, it was never going to be straightforward with a Woman involved in it  ::) ::) ::)
Offline matthewmosse
« Reply #98 on: October 09, 2017, 10:24:10 PM »
My first 550 was like that, on all pots. Still ran ok but had previously been rebuilt with lots of gasket goo and old gaskets 're used. Leaked like a sieve and didn't like to start if hot, but still get to an indicated 105 mph in that state. The bottom end was fine, must have done 10k miles without any missed gears etc. The head proved ok too and was put back in service.
« Reply #99 on: October 10, 2017, 07:43:58 AM »
Used to see that sort of damage regularly on CB175 and the K3/4 250's if the engine was "thrashed" from cold, nearest explanation i got was from a man called Stan Dibbden who was the NGK rep and used to race sidecars a loooong time ago, he reconed that it was differential expansion when haeted too quick nipping the rings and shattering them. These broken bits then worked there way out of the grooves and got hammered into the head.
As to how good he was I was servicing a two stroke 250, cant remember Suzuki or Yamaha but he picked up the plugs and examined them with an eye glass and told me to take the heads off as a piston was about to hole, he was right! and the plugs looked a good colour as well
« Reply #100 on: October 10, 2017, 08:26:53 AM »
I had to look again at the first set of pics you posted with the pistons. Now you look closely you can see the damage on the crown and the one pic you showed of the side where I commented that it was showing signs of compression loss past the rings as the skirt was burnt is No4 piston. I'm wondering though how you missed the gaping holes in the rest of them Julie, no amount of carbon would hide those holes. I've seen worse but not for many many years, damn that's a mess.
I missed the damage Ken because I wasn't looking for it at that stage. I was concentrating on the head that day and I think the pic I put on of the top of the pistons was just a random photo showing the carbon build up. It wasn't until i took the pistons out yesterday and started cleaning them up to have a closer look that i found the damage. The holes on the pistons were full of carbon and melted piston rings.
« Reply #101 on: October 10, 2017, 08:50:33 AM »
I believe the two stroke melted piston problem is pre-ignition which is usually,  as you say Bryan, related to the plugs. It's normally the plug getting too hot which is what the NGK guy was looking for and it's different to mixture. With a magnifying glass you can see if you have got any electrode melt on the plug, this shows the plug is too low a heat range ( low number in NGK) but the mixture and colour can be correct.
With road going two stroke it's plug fowling that you're trying to avoid to make them run reliably,  so you use a plug that's going to run hotter than a race motor. The risk is if you get alot of flat out running then the plug tip overheats and starts to glow red,  it's this that sets off the new mixture well before the desired timing event "pre-ignition" and causes such catastrophic heat build in the piston crown.
It's usually the opposite in a two stroke race motor. They use a plug higher up the NGK heat range which will withstand the flat out combustion heat during a race,  but of course you get that classic racer's problem of fouled plugs as they won't self clean when run at less demanding speeds.
Just broken rings in an engine leaves a characteristic imprint in the head of very sharp and defined marks,  these examples have very clear aluminium melt than only comes from detonation. As opposed to pre-ignition, this follows the start of the engine spark being timed and they are very different causes.
« Reply #102 on: October 10, 2017, 09:48:28 AM »
It shows what tough little buggers these engines are that it could bob along quite happily in the state, albeit with a slight rattle.
Way back when we first saw the bores there seemed to be signs of water damage, I was wondering if this is one of those engines that has seized over time as the rings have rusted into the bores. Along comes Bubba with his trusty breaker bar, and without pausing to wonder why it's called that, manages to free the engine and get it running, quickly flogging it on. What he couldn't see was the carnage caused to the stuck rings, ripping them out of their lands, and the debris damaging the head before eventually exiting through the exhaust port.
It could even explain the mystery of why #4 pot is ok, if that cylinder was lucky enough to be on compression, with both valves shut during the long stand.
« Reply #103 on: October 10, 2017, 10:21:41 AM »
I think that's an entirely plausible route to damage an engine and really don't think any theory should be discontinued when looking at this type of subject.
But, I would offer to counter that in the melted parts of the alloy it shows very high heat was present. If you just physically break the rings and piston lands you just don't get melting. The little craters, like moon examples, show straight up detonation of uncontrolled fuel burn and you can see the piston structure melted and smeared both up and down around that top ring area.
It's interesting that a few of these are appearing on here with this one,  matt mouse, John webbley,  the twin cylinder heads on another thread all showing what seems to be the same. We've not got pictures from some of those mentioned though.
One of the main influencers of detonation is fuel octane performance. We don't usually have anything below 95 oct now,  I think. But these bikes cover the period of two star which was 92oct with the attendant risk going up for that fuel in these engines.
Picking up on trigger saying this happened a long time ago,  I'd hold with that too judging by how much carbon was it the ring spaces. It could even have happened in the 1980s.
« Reply #104 on: October 10, 2017, 10:57:19 AM »
Could little broken bits of ring be tempoaraily embedded and glowing brightly, causing melting? Some of the head damage looks to me like physical impact rather than heat, but I agree about the piston craters looking like they were caised by melting
It would logically be harder for the heat to soak away from the piston crowns than for the head, plus its going to get hotter with blowby caused by the missing top ring heating the piston rather than leaving through the exhaust. Normally, heat applied by normal running to the piston crown would dissapate through the top ring to the cylinder bore, without that there, where would it go? Would it build up until things got so hot the piston top began to melt? It doesnt do so catastrophically because there is still a path for the heat through the surviving ring and can soak into the piston and wristpin / conrod, but could cause the damage we can see.
I agree there seems a lot of commonality with the damaged twin head we saw the other week.
What makes me dubious about the low octane or bad timing explanation is why would #4 not be just as bad?
I'm not trying to start an argument, just to make sense of a mystery.  8)
ETA: Mine was running hot on one pot due to a rock hard inlet rubber that wouldn't seal properly, I guess if number 4 sealed Ok and the rest didn't, then that would do it just with heat. Were the pipes blued?
« Last Edit: October 10, 2017, 01:01:52 PM by MrDavo »
