SOHC.co.uk Forums > CB750
K1 fork lower question
JamesH:
Burchy, on the K0/K1 the piston in the lower fork leg doesn’t need to be removed in order to withdraw the fork stanchions - hence Honda didn’t list it as a separate part. It’s just a case of removing the circlip that sits above the fork seal.
For the later K2 onwards design the piston sits within the fork stanchion and is held captive in there - hence to remove the stanchion you unscrew the allen bolt.
Sometimes people with early fork lowers still remove piston (by removing the Allen bolt) in order to properly wash-out / clean the fork lower as part of a fork seal change / polish overhaul..
Make sense?
burchy75:
I just thought it odd that it was in there and no mention of it on the microfiche itself. I originally wanted to get it to do the clean and polish as well but the bugger is well and truly stuck >:(
JamesH:
May just have to drill the head off of the allen bolt and replace after.
Bryanj:
If you use a drill that fits in the hex the head will come off doing no damage to the slider and leave the thread in the damper to unscrew when its out
burchy75:
--- Quote from: Bryanj on November 08, 2017, 07:48:16 AM ---If you use a drill that fits in the hex the head will come off doing no damage to the slider and leave the thread in the damper to unscrew when its out
--- End quote ---
I'll give that a blast Bryan
Navigation
[0] Message Index
[*] Previous page
Go to full version
