Author Topic: Engine testing out of frame  (Read 4141 times)
Offline UK Pete
« on: December 21, 2017, 04:36:07 PM »
I recently got a lovely genuine 9000 mile F1 engine, 4 years ago i bought the whole bike minus engine  , the guy bought the  bike for the engine then sold me the rest , anyway having never used the engine he contacted me and asked if i was interested in buying the engine
So i have a lovely 1976 9000 mile f1 in bits , i
Iifted the rocker cover and it's immaculate so clean, I decided as I have about 10 engines to do I might as well build a portable test rig
I have lashed together a functionable rig and will give my engine a test
Its not finished yet and it will have fan cooling and temperature gauge and oil pressure gauge, it uses a full set of electrics so I can test every thing from alternator to switch gear check the loom , regulator and rectifier etc
Also I can dial in the carbs get them spot on
when I am done I will have an attempt at painting the engine in one piece  then on too the next engine
Re: Engine testing out of frame
« Reply #1 on: December 21, 2017, 04:49:40 PM »
Great job Pete
« Reply #2 on: December 21, 2017, 06:32:04 PM »
A man after my own heart Pete..That's what I want to do for my CB250/350K engines. I don't think everyone will agree with us though, as I found here in this post :-
http://www.sohc.co.uk/index.php/topic,14569.0.html
« Reply #3 on: December 21, 2017, 06:43:35 PM »
Not got a single word to say on the subject. ;)
Offline SteveW
« Reply #4 on: December 21, 2017, 09:04:41 PM »
Did that once on a VW beetle engine and gearbox in the back garden.
Neighbours were not impressed.  ;)
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Offline UK Pete
« Reply #5 on: December 22, 2017, 06:55:56 AM »
Me personally I think it's a great idea,I don't know this engine so I want to know it' runs ok before going to all the hassle of painting it and fitting it
So it makes sense to me.
Realistically the first thing you do when you fit an engine in a bike is to get it all running and set up before you ride it which means reving it up doing timing with a strobe light, sync carbs check for leaks etc
I personally don't understand the arguments against
« Reply #6 on: December 22, 2017, 01:57:12 PM »
How would you know it was good by running it for a while ?
The pistons in the pictures came out of a bike that one of my customer had bought from a well known importer and breakers . Described as a low mileage bike (2,420) which I can say is correct by the condition of the internals and ran sweet as a nut for the first year (700 miles), with good compression until number 1 cylinder started to lose compression due to it had been sitting about for 40 plus years. The compression was good until the rust burnt off  ;)
« Last Edit: December 22, 2017, 02:01:49 PM by Trigger »
Offline UK Pete
« Reply #7 on: December 22, 2017, 06:04:53 PM »
(Attachment Link)
(Attachment Link)
(Attachment Link)
Oh wow , yes a good point
Offline UK Pete
« Reply #8 on: January 12, 2018, 12:47:56 PM »
Here is the link https://youtu.be/3i-E6HajdSA
Well I had some spare time so I got it all plumbed in , spun it over with rocker cover off to make sure oil was circulating then fired it up , oh wow it's a nice engine will need carbs tuning as it's lumpy on tick over, but a total success on my engine tester, so plan is to tune it all up get it running   sweet then paint it so it's ready for installation
« Reply #9 on: January 12, 2018, 03:55:08 PM »
Very good Pete, I love a bit of a Heath Robinson inventing.
« Reply #10 on: January 12, 2018, 05:48:28 PM »
I'm impressed Pete!
Sent from my Moto G (5) using Tapatalk
