Author Topic: Honda cb 750 fuses  (Read 6049 times)
Offline MeilakJ
  • Life is what you make it!!
Honda cb 750 fuses
« on: January 07, 2018, 06:41:37 PM »
Could anyone advice best place to get fuses for the Honda cb fuses .
They have a particular size and I need all of them 5,7,15
Offline Seabeowner
Re: Honda cb 750 fuses
« Reply #1 on: January 08, 2018, 09:57:41 AM »
I'll bump this up for you. Not sure if they are 25mm or 30mm (1", 1 1/4") on 750. 30mm easier to get.
He has them all, but you may find cheaper.
https://www.ebay.co.uk/itm/ELECTRICAL-25mm-LONG-GLASS-FUSE-FUSES-PACKET-OF-5-IN-5amp/271523029781?hash=item3f3808a315:m:mw03RBqEGG3roWiBQZmyfAA
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline MeilakJ
« Reply #2 on: January 09, 2018, 09:58:45 PM »
Thanks alot
« Reply #3 on: January 10, 2018, 09:11:27 AM »
Maplins sell 'em
« Reply #4 on: January 10, 2018, 09:29:04 AM »
Maplins sell 'em
Don't think there are Maplins stores on Malta!
« Reply #5 on: January 10, 2018, 09:31:18 AM »
Maplins sell 'em
Don't think Maplins sell 25mm fuses, only 20 and 31mm
« Reply #6 on: January 10, 2018, 04:38:13 PM »
They're 32mm or 1.25" .  I know Maplins sell them because I bought them there for Hobart dishwashers.
« Reply #7 on: January 10, 2018, 06:38:34 PM »
They are 25mm on the early CB750 and CB500 Four and Maplins don't sell 25mm fuses  ;) Subject is Honda CB 750 fuses  ;D ;D
Greebo
« Reply #8 on: January 11, 2018, 12:33:09 PM »
After having hassle with the unreliable glass fuses which I purchased from different places,i then had a break down due to a blown fuse & the recovery firm that came out to me in the middle of nowhere did not have any glass fuses & I had used my spare. Nightmare !
 So I converted mine to spade fuses,they will go in the original box/cover & you can buy them anywhere..... even in Malta ;D,
« Last Edit: January 11, 2018, 12:37:28 PM by Greebo »
Offline MeilakJ
« Reply #9 on: January 12, 2018, 07:57:34 PM »
HI All ,
Thanks for your comments and suggestions! we do not have maplin obviously but the first suggestion I had sees fine and I have ordered them. Only one that is not exactly is the 7 amp as 7.5 amp was the closest .
When they arrive I will inform you how they fit  :)
