Author Topic: Silicone Brake fluid  (Read 5235 times)
« on: January 15, 2018, 02:49:43 PM »
Have had someone ask me to service his brakes but, they are insisting that I use DOT 5. My supplier only lists 5.1, is there any difference ?
Offline RGP750
Re: Silicone Brake fluid
« Reply #1 on: January 15, 2018, 02:52:11 PM »
Found this Trigg
Image result for difference between dot 5 and 5.1
Since DOT 4 and 5.1 are both glycol-based brake fluids they are compatible with each other, which means they can be readily mixed without harming your brake system. It is important never to mistake DOT 5.1 (glycol-based) with DOT 5 which is silicone-based and should never be mixed with any other DOT fluid.
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
« Reply #2 on: January 15, 2018, 03:00:48 PM »
Found this Trigg
Interesting, but why not just use DOT 4 ? Any benefits to using 5.1 or draining the whole system and using DOT 5 ?
Offline Green1
« Reply #3 on: January 15, 2018, 03:18:58 PM »
The only benefit I can see with DOT 5 silicon based is its kinder to the paint and supposedly doesn't need to be changed as often.
I think it also has a higher boiling point not that that's ever an issue for road use.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Moorey
« Reply #4 on: January 15, 2018, 03:25:41 PM »
DOT 5 is hydrophobic. So doesn't require changing as often and doesn't damage paintwork. Allegedly.  :)
Offline Green1
« Reply #5 on: January 15, 2018, 03:28:38 PM »
That's what I said  :P
I don't trust the paintwork claim. Someone needs to try it out.  ;D
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline UK Pete
« Reply #6 on: January 15, 2018, 03:43:52 PM »
Yes dot 5 is silicon and gives a good shine to your paint when you wipe it off much better for our classics paintwork
« Reply #7 on: January 15, 2018, 03:50:24 PM »
If you use silicone fluid in a system previously filled with a non silicone fluid you need to change all the seals apparently otherwise they will swell.
« Reply #8 on: January 15, 2018, 05:40:09 PM »
Buy a litre and send it to me, I have some tanks to try it on  ;D ;D ;D
Offline Green1
« Reply #9 on: January 15, 2018, 05:50:41 PM »
I will buy you a litre and personally deliver it to your door if you do my pegaso headrace bearings.  ;D
Still haven't touched the dam thing finally get the free time but been too ill to do them.  >:(
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #10 on: January 15, 2018, 06:04:06 PM »
It is a Italian bike, just squeeze another bit of tin foil in the gap  ;)
Offline Moorey
« Reply #11 on: January 15, 2018, 06:10:23 PM »
A  bit of reading for anyone interested. http://www.buckeyetriumphs.org/technical/Brakes/Fluid/Fluid.htm
Offline Green1
« Reply #12 on: January 15, 2018, 06:11:33 PM »
Your getting as bad as Hairy  ;)
Nothing wrong with Italian bikes.
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #13 on: January 15, 2018, 06:19:31 PM »
Never seen you on one yet  ;)
Offline Green1
« Reply #14 on: January 15, 2018, 06:23:53 PM »
My Guzzi managed about 1000miles before springing a leak and the Aprilia managed about 300miles this year what more do you want .  ;D
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
