CB750
top tube frame mod
Topic: top tube frame mod (Read 5089 times)
haynes66
top tube frame mod
January 25, 2018, 09:04:43 PM »
ive had a quick search but cant find much info about this mod. after struggling to remove the frame from my F2 engine (on its side) i can now see the benefits. i have both read rep and britain frames lined up for powder coat but might be worth my while doing this mod now. any thoughts on butchering a pair of classics? it's not visible though so the purists wont foam at the mouth too much...
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Nurse Julie
Re: top tube frame mod
January 25, 2018, 09:24:19 PM »
I can't remember the make but James H has fitted one.
Nurse Julie
January 25, 2018, 09:59:33 PM »
Gordon Frame Kit.......I knew it would come to me eventually
https://m.youtube.com/watch?v=CIMfpKsK0Ho
Last Edit: January 25, 2018, 10:01:46 PM by Nurse Julie
haynes66
January 25, 2018, 10:08:48 PM »
that's the one! i knew i'd read about it somewhere. bit steep at $175 though, especially as i need two
honda firestorm
YGS1 80cc yamaha
LE Velocette
hairygit
January 25, 2018, 10:09:57 PM »
Ordinarily I wouldn't fit one, but absolutely not to a Britain or Read rep, the people who pay good money for them would run a mile from a butchered frame. After all, Honda put that bracing under the main tube for a good reason, and I certainly wouldn't ride one like it. Do you expect to blow a head gasket or worse on a regular basis? If not, leave well alone, bolted in bits are never as strong as welding, plenty here have used them, but I wouldn't.
Moorey
January 25, 2018, 10:14:18 PM »
I seriously considered it, but dismissed it. In reality how many times will you hopefully have to take the engine out or do top end work.
haynes66
January 25, 2018, 10:15:38 PM »
valid point. i'll stick with standard. i'll just have to bandage the frame really well when refitting. quite a squeeze though. but like you said, once theyre rebuilt, i hopefully wont need to take anything apart again
honda firestorm
YGS1 80cc yamaha
LE Velocette
MCTID
January 26, 2018, 11:18:08 AM »
Heres some info about the Honda Top Tube modification a US Dealer sells/ installs.....but there's nothing stopping you making up your own or getting a Local Fab Shop to machine the parts for you.....after all it doesn't look like rocket science to me.
I also agree that it wouldn't be advisable on a very valuable bike such as a PRR/ Sandcast etc as a 'purist' might be put off buying it in the future, but for a daily user/ track bike I can see the benefits.
http://carpyscaferacers.com/shop/body-parts-and-accessories/frame-adapter-honda/
archmill
SOHC Member
March 19, 2018, 09:47:54 PM »
Guy's, I made up my own frame kit in 2012 I think ( posted photo's at the time) and there was quite a bit of interest at the time. Now I've got my own machine shop and have made a few kits which are a lot cheaper than the Gordons kit from USA. Also remember Auntie Theresa will rip you off for import duty and then add VAT and then hold it to randsom with their 'approved carrier' with a fifteen quid delivery charge even after you have paid for delivery when you bought it in the USA.
JamesH
March 19, 2018, 10:48:10 PM »
Great work. Saw those listed on eBay only this week. Will def buy a kit and try it out...
Reply #10 on:
March 20, 2018, 07:05:57 AM »
If you remove all the correct bits and get the engine at exactly the right angle they do come out with no frame damage, when it was a common thing(late 70'S) due to bad services causing cam damage I could do them on my own but that was a long time ago and what with arthritis and Guinness consumption I could not even remember what to take off the engine, never mind attempt the job!!!
MarkCR750
Professional half wit and member
Reply #11 on:
March 20, 2018, 07:59:53 AM »
Getting the frame back over the engine is really easy with the engine on it’s side, no struggle at all so although it’s always wise to protect the newly painted frame it goes on so easily its almost unnecessary to protect, I can’t speak for removing the engine using the “on side†method because I stupidly removed the engine with the bike vertical and struggled like mad!.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Moorey
Reply #12 on:
March 20, 2018, 09:59:49 AM »
Even though I seriously considered doing it. Now I wouldn't by a bike that had, had it done. Its a short cut done for those racing and having regular top end work done
neilg
SOHC Associate
Reply #13 on:
March 20, 2018, 02:23:34 PM »
http://www.cyclexchange.net/frame__end.htm
Good Ol CycleX
CB750
top tube frame mod
