Author Topic: phil read rep/honda britain restoration  (Read 31986 times)
Re: phil read rep/honda britain restoration
« Reply #45 on: February 21, 2018, 05:59:42 PM »
In Reading?
Offline haynes66
« Reply #46 on: February 21, 2018, 06:04:22 PM »
the blasters are in reading, the race bike is in the cotswolds area.
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
« Reply #47 on: February 22, 2018, 07:58:50 AM »
Try I Cleenz Machines. They are based in Penge, SE London. They do a lovely job of vapour blasting and painting.
They also attend all the Kempton Park shows where they will collect and return parts if nearer to you.
Offline haynes66
« Reply #48 on: June 23, 2018, 07:48:14 AM »
so here we are again, attempting to drag myself out to the shed.  my engine cases are nicely painted so that's a bit of an incentive.
but i noticed after taking all the masking off that i made a classic mistake. i left the countershaft bearing in place.  Doh!!  never mind. DS will be pleased...
honda firestorm
YGS1 80cc yamaha
LE Velocette
« Reply #49 on: June 23, 2018, 07:59:10 AM »
Looks very Black  ;) Looks like the cases have been bead blasted ?
Offline haynes66
« Reply #50 on: June 23, 2018, 08:29:33 AM »
they were aqua blasted but i'll be giving them a blow through and a wash before doing anything. there is no visible medium anywhere but the ali feels dusty, if you know what i mean.  the outer case with 'honda' embossed will need careful sanding to get the original finish. going through my DS shopping list at the moment.
honda firestorm
YGS1 80cc yamaha
LE Velocette
« Reply #51 on: June 23, 2018, 08:43:38 AM »
The fecked bearing is just a STD NTN 6204  ;)
« Reply #52 on: June 23, 2018, 10:50:10 AM »
Always an incentive when you begin to see the hard work paying off. Well done, keep posting the progress.
Offline haynes66
« Reply #53 on: June 23, 2018, 11:17:46 AM »
thanks trig. i wasnt sure which one it was on the parts list.
honda firestorm
YGS1 80cc yamaha
LE Velocette
Offline adespin
« Reply #54 on: June 23, 2018, 12:12:02 PM »
bit of a set back as i dropped my engine cases etc for blasting and painting at a company in reading, but the wait is at least six weeks. never mind, i'll plod on with the frame etc while i'm waiting.  on the plus side, i found the owner of the actual phil read TT winning bike which is incomplete, but i did touch the engine in a pervy way!!  every cloud....
I'm confused, i thought you lived in Carmarthen, but you dropped your cases off in Reading ? Is there not a company closer that can do the job ?
1971 cb750 K1
Offline haynes66
« Reply #55 on: June 23, 2018, 02:31:26 PM »
i chose cox's in reading as they do allen millyards cases, so good recommendation. another reason is:-  one son in uni in london and the other at oxford so sort of en route really. the Britain engine isnt getting the full treatment as i know it ran in 2013 or thereabouts, so the only parts for blasting will be the top end, by a company down pembrokeshire.
honda firestorm
YGS1 80cc yamaha
LE Velocette
Offline Zunspec
« Reply #56 on: June 24, 2018, 11:11:08 AM »
Hello haynes66,
An alternative source of vapor blasting, and other restoration services, is Griff's Reality Motorworks in Bristol.
http://realitymotorworks.com/
They do excellent work at decent prices and might be more more conveniently located for you.
Cheers  Geoff
Offline haynes66
« Reply #57 on: June 24, 2018, 04:07:37 PM »
thanks for that.  i must say i am a little surprised at the work on these cases. as i'm removing all the masking tape, there is a fine pink dust in places and it does look as if the insides of the cases have had a blasting. it means a bit more washing down and blowing everything through with an air line. the bearing i removed also had fine grit in it. the finish is good though.
honda firestorm
YGS1 80cc yamaha
LE Velocette
Offline haynes66
« Reply #58 on: July 02, 2018, 08:37:35 PM »
finally dragged myself out to the shed and made some progress. i'm waiting some assembly lube to keep the shell bearings in place, but that's the bottom end done, mostly.
honda firestorm
YGS1 80cc yamaha
LE Velocette
Offline UK Pete
« Reply #59 on: July 02, 2018, 09:35:52 PM »
Keep going Pete. I have not got anywhere this year with my projects
