Author Topic: swingarm stuff  (Read 4787 times)
Offline Crispy
swingarm stuff
« on: February 22, 2018, 05:28:15 PM »
hi all,
hasn't taken long for me to ask my first question!
on stripping down my K1 swing arm I discovered it was damaged and ordered a replacement. It was upon examining the replacement that I realised that the collar ( part 12) was missing entirely from the original swing arm, no wonder it was damaged!  The replacement looks identical but the original pivot pin (15) will not fit through the collar,  according to the parts manual these parts are common to the K0,K1 & K2..it would be nice to know what am I missing here before I shell out on a new collar. Can anyone enlighten me?
Re: swingarm stuff
« Reply #1 on: February 22, 2018, 05:38:56 PM »
Has either your original swing arm or the replacement got needle roller bearings fitted instead of standard bushes?
Offline Crispy
Re: swingarm stuff
« Reply #2 on: February 22, 2018, 05:52:06 PM »
No..both got the standard parts apart from the original missing the collar.
Offline r1_pete
Re: swingarm stuff
« Reply #3 on: February 22, 2018, 09:12:00 PM »
I thought all sohc were 14mm spindles, the dohc went to 16mm, I have modified a dohc to fit my K1, it uses needle rollers, was wider and longer than the K.
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Re: swingarm stuff
« Reply #4 on: February 22, 2018, 10:15:43 PM »
Mic the original spindle - o check if its not rusted, corroded and hence oversize - might have been damaged due to missing spacer. Conversely, check the bushes in the replacement swingarm in case they've been damaged - sounds obvious but got to be one or the other.
Offline Crispy
Re: swingarm stuff
« Reply #5 on: February 22, 2018, 10:49:17 PM »
Cheers...will do that tomorrow..I don't suppose it would take much of a blemish to cause a problem.
Re: swingarm stuff
« Reply #6 on: February 23, 2018, 06:43:44 AM »
What you are calling a pivot is only a bolt, the collar is trapped in the frame by tightening the bolt and so does not turn--the bushes turn on it, i dont think the diameter or length of the collar varies accross all the 750 but the grease holes and spirals(or lack of) do
Offline Crispy
Re: swingarm stuff
« Reply #7 on: February 26, 2018, 08:45:45 PM »
Well I measured the internal diameter of the collar 13.92mm and the external diameter of the Pivot Bolt 13.93 ..(an average of 4 measurements each) so I guess it's pretty close...there must be a bit of corrosion or other distortion somewhere...I'll  just get a new collar when I get round to reassembly and see if it fits then.
Pleased to have got the old bushes out without any hassle after following the tips picked up on this forum... thought that would be harder than it was ..thanks!  :)
Offline kettle738
Re: swingarm stuff
« Reply #8 on: February 28, 2018, 01:20:00 PM »
Could your pivot bolt have had a fresh coat of bright zinc plating and 'grown' enough to prevent it getting inside the collar?
Every time I have spindles or the like zinc plated it's usually necessary to remove it from close fit areas.
Just a thought............Mick.
Offline Crispy
Re: swingarm stuff
« Reply #9 on: February 28, 2018, 02:20:01 PM »
Hi,
Yes that is a distinct possibility..it does look quite 'shiny'! That would also explain why the original collar was left out!  Bit drastic tho...it's getting me a bit worried about what else that owner did..especially regarding the motor!  :-\
Re: swingarm stuff
« Reply #10 on: February 28, 2018, 04:46:17 PM »
Why not get a quote from Phillpots to hard chrome & grind to size as already suggested I think.
Offline Crispy
Re: swingarm stuff
« Reply #11 on: February 28, 2018, 05:03:33 PM »
I think that is what I will possibly end up doing, will check it on a new collar first but I am sending my fork top tubes there so could send it with them.
« Last Edit: February 28, 2018, 05:35:18 PM by Crispy »
Offline Crispy
Re: swingarm stuff
« Reply #12 on: March 16, 2018, 10:54:56 PM »
Update on this...I Paid a visit to David Silvers while in the area and got hold of a new collar... The pivot bolt fits through this one .....looks identical to the old one but obviously isn't...anyway problem sorted now thanks!   :)
Re: swingarm stuff
« Reply #13 on: March 16, 2018, 11:29:55 PM »
I will put money on a previous owner trying to beat out a siezed collar with a big bolt and putting a burr on the inner edge
