Author Topic: 1978 CB750K Dashboard  (Read 3175 times)
Offline alexojones
« on: March 03, 2018, 07:02:43 PM »
Anyone know where I can get a replacement baseboard cover / sticker for a 1978 CB750K ( American import ) but I think the part would be same a UK version or would I have to buy a whole new Dashboard! Thanks Alex
Offline haynes66
Re: 1978 CB750K Dashboard
« Reply #1 on: March 03, 2018, 09:25:15 PM »
you mean the bit that covers the idiot lights?  i'm pretty sure you can get them on ebay or david silver.
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline alexojones
« Reply #2 on: March 03, 2018, 09:57:09 PM »
Yep that’s the one , I’ve tried David Silver and I can’t seem to find one on eBay I can only see the oblong ones for later models , thanks for advise though.
« Reply #3 on: March 03, 2018, 10:12:28 PM »
Are you on about this type ? if so contact a member by the name of Piki, he can make a decal  ;)
https://www.ebay.co.uk/itm/Honda-CB400-F-Warning-Light-Cover-Ignition-Oil-Neutral-CB400f-cb750-500-550-/112235025996?hash=item1a21ba964c
« Last Edit: March 03, 2018, 10:26:45 PM by Trigger »
Offline alexojones
« Reply #4 on: March 04, 2018, 08:27:27 AM »
Great thanks , that’s the type . I’ll contact them now .
Offline sprinta
« Reply #5 on: March 04, 2018, 09:59:30 AM »
Offline kent400
« Reply #6 on: March 04, 2018, 11:31:56 AM »
These warning light cover are a pattern part, quite OK but you need to check the lenses are secure in the cover as they have been known to fall out. A spot of two part resin adhesive on the inside around the lens corners would be a wise move. Re-fitting with the correct screws is important.
Offline alexojones
« Reply #7 on: March 04, 2018, 11:59:24 AM »
Thanks for the advise , much appreciated , I’ve ordered one  and will use the resin adhesive.
