Author Topic: CB400 Oil Way Plug  (Read 5537 times)
Offline Deano400
CB400 Oil Way Plug
« on: March 07, 2018, 04:59:49 PM »
Can anyone advise on the best way to remove this plug, see pic. I am assuming it's removable as the parts manual shows it has an O ring. It feels tight and I don't want to use any unnecessary force. Does it just pull out with a bit of effort? Would like to replace the O ring when I rebuild. Cheers.
Offline Orcade-Ian
    • Older Vehicle Web
Re: CB400 Oil Way Plug
« Reply #1 on: March 07, 2018, 06:11:08 PM »
Yes, just pulls out and has an o ring on.
I remove them with a small 3 jaw chuck gripped around the pin and apply a little heat if needed.
Ian
Definitely replace the o ring, especially if any extra heat was needed to extract it
« Last Edit: March 07, 2018, 06:29:49 PM by orcadian »
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline Deano400
« Reply #2 on: March 07, 2018, 08:28:25 PM »
Thanks Ian great help. Like the 3 jaw chuck idea. Think I'll leave the hammer action off!!  :)
« Reply #3 on: March 08, 2018, 12:04:13 AM »
Remove the bung on the over side of the engine and then take a long bar and knock it out  ;)
Offline ttr400
    • CB400F special machined parts
« Reply #4 on: March 08, 2018, 04:57:55 AM »
What Trigger said.
Kevin
If you are addicted to the little CB400F then you might want to check out my website.
www.ttr400.com
Offline tom400f
« Reply #5 on: March 08, 2018, 09:58:39 PM »
*cough* if you run the starter it might come flying out under oil pressure  ::)
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline Deano400
« Reply #6 on: March 09, 2018, 05:52:10 PM »
Gave it a slight tap and it flew out!!  :) :)
« Reply #7 on: March 09, 2018, 07:49:52 PM »
Exactly what it does if you start the engine with out the generator cover on, closely followed by looooods of oil
« Reply #8 on: March 10, 2018, 12:19:24 PM »
I learned that lesson ;D ;D
Offline Greg65
« Reply #9 on: March 10, 2018, 09:18:07 PM »
Bit of background to this please. Is this just good sense to replace a 40 year old seal or are there other benefits such as cleaning the oil passage?
Greg
Keep smiling it makes the management nervous.
Honda CB400 1976
Suzuki GS1000 1978
« Reply #10 on: March 10, 2018, 09:48:40 PM »
How far down are you stripping the motor? Right down to bare cases? If so, yes, flush it through and dry with compressed air. If not splitting the casing, just replace the O ring, don't risk dislodging dwarf or sludge, last thing you need is for it to be loose in the oil when you run it.
Offline Greg65
« Reply #11 on: March 11, 2018, 07:43:40 AM »
As the case is split I will open them up and check for dwarfs, don’t want any singing going on in my engine ;D.
Thanks Hairy, I just love auto correct.
Honda CB400 1976
Suzuki GS1000 1978
Offline andut
  • CB400F, CB400F Cafe & NC30
« Reply #12 on: March 11, 2018, 08:15:14 AM »
Best to check for midgets in the rocker cover whilst you're at it ........
Offline Rozabikes Tim
« Reply #13 on: March 11, 2018, 08:30:11 AM »
Does it have one of those "Hiho" chains in there? I was a bit Dozey once and overlooked that one!
« Reply #14 on: March 11, 2018, 01:47:27 PM »
Hiho,  wasn't that used by Jeff beck combined with silver lining? As well as the obvious dwarf usage.  :)
