CB350/400
Plastic 5 pin plug for Ignition
Topic: Plastic 5 pin plug for Ignition (Read 2408 times)
ogri211
SOHC Member
March 28, 2018, 09:25:21 PM »
While checking my wiring on the rebuild I noticed that my ignition switch was connected to the loom with 5 individual spade connectors, this would have originally been a multi plug does anyone know if I can buy the correct one of these plugs to fix it to the switch.
Triumph Rocket3, Suzuki GT 750A, Kawasaki H1B, Honda 400 Four, Triumph Speed Triple
Deano400
Re: Plastic 5 pin plug for Ignition
March 29, 2018, 09:58:54 AM »
Steve will cut plugs off old harnesses that you can splice in.
http://www.400fourbits.co.uk/
Deano400
March 29, 2018, 09:59:42 AM »
Alan can probably supply all the bits you need new.
http://alans-electrics.alanlowe.co.uk/home
BigAl (Alan)
Hope its sunny at the weekend
March 29, 2018, 02:37:15 PM »
I have all of the 6.3mm OE square latched connectors (and some un-latched) in stock, if you do require a pair/set, then please PM me.
Normally I do not sell individual parts, but for members on this site & VJMC I do make the exception.
Alan
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
www.alans-electrics.co.uk
ogri211
SOHC Member
March 29, 2018, 08:47:37 PM »
Thanks for the input if the the connector is a standard 6.3 6 connector plug I think I may have one I am away from home just now working I should be able to sort something out.
ogri211
SOHC Member
March 30, 2018, 07:43:24 PM »
Ive contacted Steve at 400four parts and he is going to sell me one with a foot of cable so I will be able to solder and heat shrink it onto my original wiring.
CB350/400
