Author Topic: 1969 K0 diecast  (Read 2978 times)
1969 K0 diecast
« on: March 29, 2018, 12:07:01 PM »
11/1969 K0 diecast barn find, unsiezed, £3,999 from the frog dude.
https://www.ebay.co.uk/itm/Honda-CB750-CB-750-K0-1969-Diecast-Barn-Find-Project-A-MUST-SEE/222901637370
The wrinkle tank appears to have taken a direct hit with a cannon round, but that's the yanks for you. worth saving but it would be a hell of a patch. Recessed ignition switch, battered but correct clocks. 5.00 x 16 back wheel, shot pipes. Engine cases are chromed and peeling but strippable I guess. Last taxed 1982 from the plate.
Bar operated carbs, I believe correct for a later K0, no number given.
A bit of a mess, but he hasn't been at it with the easy start, DK would've. Could be a good resto project if you had the time and  parts.
Offline UK Pete
Re: 1969 K0 diecast
« Reply #1 on: March 29, 2018, 12:12:29 PM »
Would need 5 or 6k to make right and good standard
But yes nice project
Re: 1969 K0 diecast
« Reply #2 on: March 29, 2018, 12:15:19 PM »
I wonder if the bullet is still in the tank?
Offline UK Pete
Re: 1969 K0 diecast
« Reply #3 on: March 29, 2018, 12:16:22 PM »
Offline RGP750
Re: 1969 K0 diecast
« Reply #4 on: March 29, 2018, 12:22:44 PM »
Looks about as much work as i had to do on mine except i had correct cable carbs,mine is 11 69
I recon i spent 8 and that was doing it all pretty much myself .
Worth saving though
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline UK Pete
Re: 1969 K0 diecast
« Reply #5 on: March 29, 2018, 12:25:20 PM »
Worth saving though
Yes at least 8 needed to make it correct
But most people seen to go with non correct easy available parts now
Offline RGP750
Re: 1969 K0 diecast
« Reply #6 on: March 29, 2018, 03:38:38 PM »
I only paid £1500 for mine though ::) :D :D
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
