Author Topic: 750 K1 project  (Read 95203 times)
Re: 750 K1 project
« Reply #90 on: July 22, 2018, 03:50:00 PM »
Can't see if you have the roll pin fitted and are all the half rings in ?
Have you done a dry run, to make sure all gears select .
« Last Edit: July 22, 2018, 03:52:03 PM by Trigger »
Offline Crispy
Re: 750 K1 project
« Reply #91 on: July 22, 2018, 04:44:08 PM »
Yes..I have the three half rings and the roll pin that holds the kickstart shaft...crank seal and final drive oil seals are in now...trial fitting ok ..but I'll do it again and try the gear shift this time! 🙄
« Last Edit: July 22, 2018, 04:46:13 PM by Crispy »
Offline Crispy
Re: 750 K1 project
« Reply #92 on: July 22, 2018, 04:59:58 PM »
Woohoo!....I can get 5 gears 😀
Re: 750 K1 project
« Reply #93 on: July 22, 2018, 05:05:21 PM »
Offline Crispy
Re: 750 K1 project
« Reply #94 on: July 22, 2018, 06:11:58 PM »
 Bottom half back together, with Julie & Triggers timely help and advice, 🙌 thanks so much...having the knowledge of you guys available is so invaluable...got to get the top end sorted now but I'm pleased to get this bit done before I forgot where everything went! 💪
« Last Edit: July 22, 2018, 06:16:57 PM by Crispy »
Re: 750 K1 project
« Reply #95 on: July 22, 2018, 06:58:39 PM »
Lookin good. Painting my cases tomorrow  :)
Re: 750 K1 project
« Reply #96 on: July 22, 2018, 09:26:24 PM »
Yeah looks really nice... its better if you can split the cases for painting. Mine was painted without splitting, as the motor internals seemed ok so a shame to split, but the painting looks betterr on yours.
Offline Crispy
Re: 750 K1 project
« Reply #97 on: July 22, 2018, 10:11:26 PM »
Cheers Guys, it's also easier to get it in the oven for curing 😉
Re: 750 K1 project
« Reply #98 on: July 22, 2018, 10:27:21 PM »
Looks like everyone is building K1's. I will have this one finished by the end of the week  ;)
Offline Crispy
Re: 750 K1 project
« Reply #99 on: July 22, 2018, 10:58:32 PM »
Nice one..just noticed on your lower case, the large round section has a securing clamp on it which mine doesn't have. It has the post for the bolt but it is undrilled. I assume some have it and others don't ?
Re: 750 K1 project
« Reply #100 on: July 22, 2018, 11:04:51 PM »
That's because it is a it is a early K1 and yours is later  ;) Yours also has M6 flanged engine bolts and the one i am doing is the non flanged type. The oil bungs on the early's have a 17 AF and all later units were fitted with 14 AF.
Offline Crispy
Re: 750 K1 project
« Reply #101 on: July 23, 2018, 07:39:23 AM »
Cheers Trigger...I must be turning into some sort of anorak! ...I find all these little differences/changes quite fascinating!  😬
Re: 750 K1 project
« Reply #102 on: July 23, 2018, 09:19:38 AM »
I would not say that it is being a anorak, it is just knowing the history of your bike.
The K1 was fitted with two different types of crank cases fitted. The early K1's had the crank cases used from the K0's  ( with slight changes in the castings ) and moved on to the later cases, which were used on some of the K2's.
The engine evolved over the years with 3 different types of oil pumps, 3 different clutch baskets, 2 different selector drums and so on. I don't need to see a engine numbers to know what year it is  :o Or if it has the wrong barrels or head fitted for that year. I have never found anyone that has wrote a book on all the correct detailing of the CB750K engines.
Re: 750 K1 project
« Reply #103 on: July 23, 2018, 01:19:47 PM »
Maybe it's time you started Graham ;)
Re: 750 K1 project
« Reply #104 on: July 23, 2018, 11:22:34 PM »
Books Paul, i can't even be bothered to read one, never mind write one. Never seem to have time with members asking questions and looking for parts all day  ;D ;D ;D
