Author Topic: Can anyone please identify these parts from a 400/4?  (Read 4882 times)
Offline Paul Smith
« on: April 12, 2018, 08:30:04 AM »
I'm down to the last few parts I can't identify where they go! Picture 1 is a small painted bracket that I have 1 off, picture 2 is a bolt with a hole drilled through the middle that I have 2 off and picture 3 is a small curved item with a tapped hole in the centre of it that I have 4 off. Silly bits but probably vital!! [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
1975 Honda CB400F
1979 Suzuki GS750
1975 Suzuki GT250
1981 Suzuki TS185
I Just love classic '70's Jap bikes
Re: Can anyone please identify these parts from a 400/4?
« Reply #1 on: April 12, 2018, 08:36:30 AM »
Pic 2 looks like the bolt that the metal brake pipe into the brake caliper goes through.
« Reply #2 on: April 12, 2018, 08:41:35 AM »
#3 is a stay mounting rubber
#2 not sure need more pic's and measurements
#1 is a seat plunger bracket
Offline Paul Smith
« Reply #3 on: April 12, 2018, 08:41:50 AM »
The brake pipe is complete, the bolt is also threaded at the hex end/
1975 Honda CB400F
1979 Suzuki GS750
1975 Suzuki GT250
1981 Suzuki TS185
« Reply #4 on: April 12, 2018, 08:45:40 AM »
Is the bolt in number 2 threaded on the inside on the hex end ?
Offline Paul Smith
« Reply #5 on: April 12, 2018, 08:49:02 AM »
Thanks Trigger, that's a great help. I've attached some more pics of the bolt that is threaded. [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
1975 Honda CB400F
1979 Suzuki GS750
1975 Suzuki GT250
1981 Suzuki TS185
« Reply #6 on: April 12, 2018, 08:55:14 AM »
Right, with a better view, that is a headlamp bowl bolt, and reflectors screw into the internal thread.
« Reply #7 on: April 12, 2018, 08:56:53 AM »
Should not have a hole all the way through and looks like a head light mounting bolt, that the reflector screws too.
« Reply #8 on: April 12, 2018, 09:16:02 AM »
Could be one of D.S's pattern ones, not actually seen one first hand, but an engineering company would probably find it easier than clearing and tapping a blind hole.
« Reply #9 on: April 12, 2018, 09:28:24 AM »
You could be right mate, its a bugger trying to clean out a blind hole after tapping  ;)
« Reply #10 on: April 12, 2018, 09:33:42 AM »
#3 is a stay mounting plastic  :)
« Reply #11 on: April 12, 2018, 09:35:42 AM »
You need to use all 3 taps in a set to do a blind hole, finishing with a plug tap, and as you say cleaning it of all swarf afterwards. Far quicker (And of course cheaper) to drill and tap straight through. I did have some metric drill and tap combined bits years ago, but buggered if I can find them now.
« Reply #12 on: April 12, 2018, 09:52:02 AM »
I had some aftermarket ones that were rubber  ;)
Offline Paul Smith
« Reply #13 on: April 12, 2018, 08:29:36 PM »
Thanks for all the replies, it does work as a headlamp bowl bolt and the reflectors fit in the end. Quite a relief as I was beginning to have a horrible feeling that they lived deep inside the engine that I've already started to rebuild!!
1975 Honda CB400F
1979 Suzuki GS750
1975 Suzuki GT250
1981 Suzuki TS185
« Reply #14 on: April 12, 2018, 09:30:27 PM »
What is my prize for getting 3 out of 3  ;D
