SOHC.co.uk Forums > CB350/400
LED console lights upgrade - tutorial
<< < (2/2)
hairygit:
Well, you should have said! Always an excuse to get out of unpaid work, should have told her it needed a 50-100 mile test run to check none of the soldered joints work loose!  ;D ;D ;D ;D ;D
mike the bike:
That's next weekend's 'chore'
BigAl (Alan):
Very handy tip. I have tried the LED equivalents (BA9S-5 SMD) within the CB750 clocks & centre consul, unfortunately they are 7mm longer than the traditional lamps (as image). Once fitted the lamp holder boots will not push into place.
mike the bike:
That's what I thought when I  saw them.
Green1:
I don't need the idiot lights to be brighter then my headlight  ;D
I put an LED pilot light in the CG Honda and its now brighter then the main beam.
It does look smart though
Navigation
[0] Message Index
[*] Previous page
Go to full version
