Author Topic: Tapping nosie  (Read 11174 times)
Offline yozzer74
Tapping nosie
« on: April 28, 2018, 03:31:38 PM »
My mates just got his bike running after rebuild.does the tapping noise sound ok .we regapped tappits again so there ok .https://youtu.be/xjeSlNsPSN0
Offline Tomb
Re: Tapping nosie
« Reply #1 on: April 28, 2018, 03:44:39 PM »
I had a similar noise start on a Yamaha I run, horrendous engine tapping noise, its done 99K miles so thought its knackered, turned out to be a split leaking header exhaust. Worth a check!
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline yozzer74
Re: Tapping nosie
« Reply #2 on: April 28, 2018, 03:51:26 PM »
Will do thanks
Offline sprinta
Re: Tapping nosie
« Reply #3 on: April 28, 2018, 04:28:52 PM »
Sound like clutch rattle? Does it reduce/disappear if the clutch lever is pulled in?
Offline yozzer74
Re: Tapping nosie
« Reply #4 on: April 28, 2018, 04:30:09 PM »
Nope it stays there when clutch pulled in
Re: Tapping nosie
« Reply #5 on: April 28, 2018, 05:51:01 PM »
The speed of the tapping sounds top end y.
It has got oil to both sides of the head? Hasn't it?
Take the tappet covers off to have a good look and don't run it if at all suspect.
Offline ka-ja
  • ken
  • yoshi 460
Re: Tapping nosie
« Reply #6 on: April 28, 2018, 07:25:36 PM »
Out of balance carbs. can cause rattles.
nice bike,nothing in the bank
Offline yozzer74
Re: Tapping nosie
« Reply #7 on: April 28, 2018, 07:46:41 PM »
K2 that was first thing we checked .yeah plenty of oil .will take a look at carbs .
Offline MarkCR750
Re: Tapping nosie
« Reply #8 on: April 29, 2018, 05:19:48 PM »
Hi Yozzer, as above I had that noise on mine and it was a leaking exhaust copper crush gasket, sounded very metallic, great relief when I check tightened the headers and it went away!
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline yozzer74
Re: Tapping nosie
« Reply #9 on: April 29, 2018, 05:28:43 PM »
Cheers mark will give it a check
Re: Tapping nosie
« Reply #10 on: April 29, 2018, 05:29:56 PM »
That's how the problem with my down pipe header is presenting itself.
Greebo
Re: Tapping nosie
« Reply #11 on: May 01, 2018, 03:12:42 PM »
Sounds like loose tappets to me, if not possibly cam chain
Offline MarkCR750
Re: Tapping nosie
« Reply #12 on: May 14, 2018, 07:53:45 PM »
Have you found out what it was/is yet Yozzer?
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Offline yozzer74
Re: Tapping nosie
« Reply #13 on: May 14, 2018, 07:57:17 PM »
Not yet mark it's my mates bike and he's away at minute
Re: Tapping nosie
« Reply #14 on: May 15, 2018, 09:08:19 AM »
I spent half a day chasing a tappet noise till i nipped up the flanges on the exhausts i fitted the month previous!
