CB750
Fact or Fiction?
Topic: Fact or Fiction? (Read 2254 times)
Arch stanton
SOHC Expert
Fact or Fiction?
May 05, 2018, 07:23:42 PM »
Hello Folks.
Was there any truth in the rumours of the day.
That the sohc 750k's were detuned after the K2.
Then the original power restored on the F1?
Just curious.
Sean.
Trigger
Re: Fact or Fiction?
May 05, 2018, 08:20:42 PM »
All the engines were basically the same ( apart from the evolution of the engines) . F1 and all F2 had higher compression domed pistons and the F2 had the bigger valves. So, were do you get this bull shite ?
Carbs are basically all the same, apart from the F2 and late K's had PD carbs
K2-K6
May 05, 2018, 08:32:59 PM »
Some info here to sort out what happened and why.
http://forums.sohc4.net/index.php?topic=7401.0
As Trigger says, all the pre F series engines are effectively the same design with no claims to a different horsepower rating for each of them, 67 BHP across the board is quoted.
Emissions and smooth running seem to have brought many minor adjustments.
Trigger
May 05, 2018, 09:03:42 PM »
Most of the little changes like the cams and the inner baffles were only on yank units. The UK K2, that ran from 1972 to 1975 were identical in the engine department internals
Arch stanton
SOHC Expert
May 05, 2018, 10:27:14 PM »
As I said. It was the word at the time.
It was also said of the Z900 & the S/KH250's
I just thought I'd raise the subject.
royhall
Keep biking I'm not quite bankrupt yet
May 07, 2018, 06:25:35 PM »
The Z900 was lighter than the Z1 due to the use of thinner wall tube on the frame. Hence the hinge in the middle reputation. It was also down a couple of horses due to emissions regulations, mainly in California.
Last Edit: May 08, 2018, 07:04:37 AM by royhall
UK Pete
May 07, 2018, 10:15:49 PM »
If you read honda mans book and posts on the us forums he mentions
That some models were down on power compared to earlier ones although the stated bhp remained the same I think he referred to the k7
Link to my Diecast K0 restoration
http://www.sohc.co.uk/index.php/topic,4827.0.html
Link to sandcast restoration
http://www.sohc.co.uk/index.php/topic,6862.0.html
Arch stanton
SOHC Expert
May 08, 2018, 10:20:29 AM »
I'm glad it's not just me who has heard this "Bull Shite".
CB750
Fact or Fiction?
