Author Topic: plug leads / caps  (Read 8198 times)
Offline pae
    • Phil's CB650 pages
plug leads / caps
« on: September 05, 2007, 12:27:00 PM »
I've read all sorts of stuff about whether the caps or leads should be resistor type, and if so whether it should be cap or the lead (which all goes over my head a bit  :-\ ).
If it makes any difference, what do I need for a '79 CB650 (which has electronic ign, not points ,if that also makes a difference).
Sorry, electrical stuff is not my game...
regards, phil
Offline dave400
Re: plug leads / caps
« Reply #1 on: September 05, 2007, 04:58:09 PM »
I have electronic ignition and use resistor caps 5k?, I don
Offline Dave M
« Reply #2 on: September 05, 2007, 05:22:42 PM »
They also act as a suppressor to reduce interference on radios etc.
Dave
Melbourne.
Offline pae
« Reply #3 on: September 05, 2007, 05:35:00 PM »
Offline dave400
« Reply #4 on: September 05, 2007, 06:14:24 PM »
Phil, I
« Reply #5 on: September 05, 2007, 06:19:26 PM »
There is lots of b****x talked about resistor leads and caps.
They are purely to suppress electric interference and as good citizens we should use the 5k plug caps.
Resistor wire is a bit OTT - use whatever you can get. Unless you are running fancy competition ignition and top end, it won't make a "hapath" of difference.
How do you spell ha'pth? (half penny worth) ?
Offline Dave M
« Reply #6 on: September 05, 2007, 07:19:40 PM »
That's right Steve.
A good quality copper cored lead with an NKG 5k resistor plug cap will do the job admirably!
Dave
Melbourne.
Offline JonnyB
    • BatchScan
« Reply #8 on: September 05, 2007, 08:10:55 PM »
Steve you southern jessie ;) , apeth, you need to drop your hay-chez, Mmmm dosen't really translate
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
John
https://batchscan.co.uk/
« Reply #9 on: September 05, 2007, 09:03:15 PM »
So Rutland is "Ooop North" now is it John ??
