Author Topic: 1970 (01/70) CB750 restoration  (Read 17380 times)
Re: 1970 (01/70) CB750 restoration
« Reply #15 on: June 09, 2018, 02:50:16 PM »
   really brilliant,
   looking great .
   hope she rides as well as she looks
Looking Great  8)
Shame we never get clean roads to use them on.
Looks so good James
Wish I had the time and money to do the same to the many bikes I have laying around
Thanks for the comments chaps; means a lot. James
Offline Sgt.Pinback
« Reply #16 on: June 09, 2018, 02:56:30 PM »
What VIN is she? I still don’t know when single cut fenders were used.
Yes, great work as usual.
cheers, Uli
Offline Sgt.Pinback
« Reply #17 on: June 09, 2018, 03:02:33 PM »
All in that range, which one is the lowest?
My 18907 came with DC.
« Last Edit: June 09, 2018, 03:12:43 PM by Sgt.Pinback »
cheers, Uli
« Reply #18 on: June 09, 2018, 03:08:19 PM »
Bike looks great James, the engine looks stunning in the frame, I remember it well 😭😭😭😭
« Last Edit: June 09, 2018, 03:30:04 PM by Nurse Julie »
« Reply #19 on: June 09, 2018, 04:59:38 PM »
Beautiful restoration James....
« Reply #20 on: June 09, 2018, 05:21:21 PM »
Tremendous job James, you have a right little production line going there.
Offline RGP750
« Reply #21 on: June 09, 2018, 06:55:52 PM »
Fantastic job James.
Will you ride it up to DS anniversary day?
May ride mine up if the weather is ok, James with the Sand cast wants to ride up, will ask Mick as well.
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline Arch stanton
« Reply #22 on: June 10, 2018, 09:00:35 AM »
Hello James.
Great work & attention to detail.
Please excuse my ignorance but. What is a single cut fender?
Also. What satin black paint do you recommend? I always used the old PJ1. But I have heard the new stuff in not as good.
Regards.
Sean.
Offline neat street
« Reply #23 on: June 10, 2018, 10:14:10 AM »
Brilliant James! great work as always. love looking at all the great work you guys (and lady) do. well done!
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline petermigreen
« Reply #24 on: June 10, 2018, 01:29:28 PM »
Hello James.
Regards.
Sean.
I was hoping someone would ask that
« Reply #25 on: June 10, 2018, 02:00:15 PM »
Me too
« Reply #26 on: June 10, 2018, 03:10:11 PM »
Hello James.
Regards.
Sean.
Hi Sean - essentially there were 4 types of front fender on the cb750.
The ‘cut’ refers to the shraper ‘cut’ finish to the leading and trailing edges of the fender (i.e not Rolled).
Sandcast and early ‘69 diescast had double-cut (so beoth front and trailing edge was cut.
Later diecast (around 12/69 or 01/70) had the single cut to the rear edge. I’ve seen these run through to early K1 production. The front edge was rolled.
From K1 both rolled edges.
From late K2 they changed the fork design so the mounting bracket changed - but the blade was again fully rolled.
Hope that helps..
Offline Sgt.Pinback
« Reply #27 on: June 10, 2018, 03:30:57 PM »
Zwo types of double cut fenders: without hole for the speedo cable holder (early sandcast) and with hole (later SC and early diecast)
cheers, Uli
« Reply #28 on: June 10, 2018, 03:45:46 PM »
Good point Uli - my 57xx sandcast has the speedo cable guide hole...
Offline Sgt.Pinback
« Reply #29 on: June 10, 2018, 03:56:24 PM »
My # 1983 has no cable holder hole. Took me almost two years to find that fender.
cheers, Uli
