Author Topic: Sparks on the points gap..  (Read 3051 times)
Offline El__burro
« on: June 10, 2018, 09:44:54 PM »
Good day, I remember having sorted the same problem (sparks on points gap) previously by replacing the condenser..
This time that alone hasn't worked. I have realized that the the rubber isolating part that goes to the hole indicated by the orange arrow (in the img attached) was damaged so I improvised something.
Could be it?
How do you replace that tiny part (if you can)?
el__burro
Sent from my SM-G935F using Tapatalk
Re: Sparks on the points gap..
« Reply #1 on: June 11, 2018, 12:35:55 PM »
New contacts as it does not come seperate mate
« Reply #2 on: June 11, 2018, 05:11:29 PM »
Some new screws as well  8)
Offline 01thomas
« Reply #3 on: June 17, 2018, 08:24:06 PM »
Silicone?
Offline spanners
« Reply #4 on: June 18, 2018, 12:56:53 AM »
Hi, to answer your question, no your broken isolation washer (if it was allowing the screw thread to touch the bracket) would kill the spark at the points and stop the engine firing on two cylinders..
Other possible reasons for excessive sparking might be - if your points are pitted, oxidised, have a high resistance across them, or if they have been cleaned maybe with emery cloth or some sort of abrasive paper, (which leaves tiny bits stuck in the points surface)
Is it only sparking bad on that set of points then?
CB750 K2
1975 CB550 K1
2004 Boxercup Replika
Offline El__burro
« Reply #5 on: June 25, 2018, 10:57:02 PM »
Actually i've replaced both condensers and points but still..
Points 2-3 produce a lot of sparks.
I have swapped the condensers around but 2-3 are still sparky.
It run great for the first few hours, then..
How do i disgnose the issue??
thanks
el__burro
« Last Edit: June 26, 2018, 02:10:20 PM by El__burro »
