General > New Member Introductions
New Member
<< < (3/3)
Nurse Julie:
I could be wrong but I think the ES is just the new version of the EA (someone will tell me if i'm wrong i'm sure !!!). I was just making sure you were not using plugs with R in the title which means resisted, with resisted plug caps as that combination gives the symptoms you are describing with the fluctuating revs. I know this as I fitted the resisted plugs in error one time and had all sorts of problems !!!. As Roy said earlier, whip the plugs out after a run to get a general idea of if she is running lean or rich, my guess would be lean which is no good at all and running long term like this can cause serious damage to the engine(see my engine rebuild thread  :'( :'( :'().
Davelu88:
Many thanks for all the replies , i will do a plug chop in the next couple of days and see whats what.
royhall:
--- Quote from: Nurse Julie on June 11, 2018, 06:25:24 PM ---I could be wrong but I think the ES is just the new version of the EA (someone will tell me if i'm wrong i'm sure !!!). I was just making sure you were not using plugs with R in the title which means resisted, with resisted plug caps as that combination gives the symptoms you are describing with the fluctuating revs. I know this as I fitted the resisted plugs in error one time and had all sorts of problems !!!. As Roy said earlier, whip the plugs out after a run to get a general idea of if she is running lean or rich, my guess would be lean which is no good at all and running long term like this can cause serious damage to the engine(see my engine rebuild thread  :'( :'( :'( ).
--- End quote ---
Yep probably lean. Sounds like an air leak to me?
Davelu88:
I couldnt find one and sprayed carb cleaner all over area to change revs but no joy , anywhere else too look for leak ?
Nurse Julie:
Absolutely anywhere that rubber meets metal or anywhere there is an opening with something in it that isn't fitting tight enough :)
Navigation
[0] Message Index
[*] Previous page
Go to full version
