CB350/400
400/4 Cibie Headlight bulb
Topic: 400/4 Cibie Headlight bulb (Read 4304 times)
Davelu88
June 26, 2018, 11:44:22 AM »
Hi all
Can anyone tell me if i can upgrade my headlight bulb to be a bit brighter , bikes standard apart from electronic ignition and has a Cibie lens fitted. I have tried searching but cant seem to find a def answer.
Davelu88
Re: 400/4 Cibie Headlight bulb
June 26, 2018, 12:43:52 PM »
Hi
its def a removable bulb but i was just wondering about charging issues etc with a modern type bulb.
Davelu88
June 26, 2018, 02:04:14 PM »
Many thx
ogri211
SOHC Member
June 26, 2018, 09:06:37 PM »
I have one of these in my bike its only 20 watts but much brighter but it will not fit in a Cibie light with the concave lens as the bulb is a bit longer than the standard and hits the glass
www.amazon.co.uk/gp/product/B01C1AOSVS/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
they can also be bought here for less than half the price
www.aliexpress.com/item/H4-Motorcycle-Headlight-bulbs-6500K-hi-lo-Bulbs-HS1-20W-2-2000LM-2Light-Moped-Scooter-Motobike/32631895395.html?spm=a2g0s.9042311.0.0.40e64c4dDx72WD
Triumph Rocket3, Suzuki GT 750A, Kawasaki H1B, Honda 400 Four, Triumph Speed Triple
Davelu88
June 26, 2018, 09:08:40 PM »
Hi
Yea mine has the concave lens
ogri211
SOHC Member
June 26, 2018, 09:14:36 PM »
It wont fit it hits the glass I took mine off and fitted a standard reflector so I could use the LED, the chinese are catching on these bulbs have went up from £8 last week to £14. One of the other LEDs might work but I haven't tried them.
mike the bike
CB400F, Royal Enfield Interceptor.
June 27, 2018, 09:52:02 AM »
I bought a pattern headlamp from M&P for a superdream. It comes supplied with a 55/60W H4 bulb. Using the original 400four headlamp shell, it does fit, just.
Davelu88
June 27, 2018, 07:13:31 PM »
I quite like the Cibie Glass but if all else fails i may have to look into that.
ogri211
SOHC Member
June 27, 2018, 07:55:02 PM »
I have also a cibie I have ordered a couple of different LED's to try if I can get one to fit with the cibie concave lens I will let you know.
K2-K6
June 27, 2018, 07:55:09 PM »
For halogen H4 bulbs I use Phillips white vision 4300k colour balance bulbs.
They are really good quality and give quite a white light for halogen at the standard 60/55 watt rating.
The Cibié light unit is known as a "Bioscar " in rally car world as I understand it. They are a good headlight with period mod look and good beam pattern I feel, worth keeping.
Davelu88
Reply #10 on:
June 27, 2018, 08:33:01 PM »
Cheers for replies, if i get anything to fit i will post also.
CB350/400
