Author Topic: Honda design failures.  (Read 2155 times)
Offline Arch stanton
« on: June 29, 2018, 09:28:00 PM »
After spending £28 on a splendid looking wheel bearing retainer removal tool. Which I should imagine I would use only once.
Did it work? Did it F!!!
So I removed the retainer the same way as I had to 40yrs earlier. With a Hammer & Chisel.
What a stupid over engineered idea.
What was wrong with a Circlip?
It ranks alongside.
Honda inboard disc brakes &
Honda cable operated disc brake.
There are times I think the designers of these things
Were sniffing glue.
Rant over.
Ah that's better.
Sean.
Ps. NR500.
Offline Green1
Re: Honda design failures.
« Reply #1 on: June 29, 2018, 09:39:35 PM »
You can't end your post NR500 without pics
Did you drill the punch mark?
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #2 on: June 29, 2018, 09:58:21 PM »
You couldn't get the head off with the engine in the frame on that one either  :D
« Reply #3 on: June 29, 2018, 11:29:50 PM »
Yup. Drilled the punch points.
I think the surface area of the threads overwhelms the strength of the aluminium its made of.
I forgot to mention the entire VF range.
« Reply #4 on: June 30, 2018, 06:58:12 AM »
Without which we’d never have had the VFR
Offline haynes66
« Reply #5 on: June 30, 2018, 07:53:11 AM »
can you stop being rude about honda design failures. i actually like my DN-01!
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline gtmdriver
« Reply #6 on: June 30, 2018, 07:58:40 AM »
They went through a bad time with cam chain tensioners too but on balance I think it is fair to say that Honda designers got a lot more right than they got wrong.
« Reply #7 on: June 30, 2018, 10:23:13 AM »
I agree. That's why they are the worlds biggest.
In my opinion. The Vfr engine. Is the best motorcycle engine ever built. By a long way.
The Cb/d engine is a masterpiece of performance/ simplicity. But lost the plot with the 200, imo.
