General > New Member Introductions
Well hello!
matthewmosse:
Check the filler cap is allowing air in as fuel goes out, had a mates bike go like that, would go a mile, stop, need slight choke to 're start and died again within the mile, until the battery gave out, he asked me to help recover it, we went out to collect it, jump leads in hand, I pulled the fuel cap off, left it slightly open and it went home fine, Turned out an aftermarket filler cap was vacume locking fuel, as no pinhole to allow air in, had similar from rust clogging the filter on the fuel tap, fuel could seep past but not fast enough to keep up with engine demand, oh and the old kink in the fuel line. Often it's a simple thing that's easily overlooked.
Ko En:
Thanks for the advice.
When I blow on the cap air goes through reasonably easy. I had tried that in the past. I lowered the floats a little bit, last thing I did before it started acting up was raising them.. Tightened the carb extra, extra, tested if petrol comes through when I open the tap, it runs out just fine, also in normal position. Started it up, was hiccuping quite extreme, set the tap on reserve: all fine. Beats me.
I'll try to take out the petcock when my tank gets lower.
Thanks again,
Ko En:
6 months onwards and a lot of work on the little orange Honda later Im still enjoying it and I'm so happy that I bought it. What a fantastic hobby.
I changed the Piston: Most rings were stuck and the only loose one was badly worn.
Drove around with that for a while but still not great.
New cam chain helped a lot, managed to change it without having to take the engine off.
It's much less noisy now, though definitely not silent.
Changed the fork oil which improved handling, wanted to change the seals but could't get the fork legs out, no matter what I tried... Will have to try that again some time soon.
The rear suspension is deteriorating (leaking some oil) and it is affecting handling.
-Does anyone know if it is possible (doable) to repair those yourself?
I've seen some cheapo's on the internet and wonder if that would be a waste of money.
-Any experience/pointers regarding cheap rear shocks/damper units?
Cheers, and happy motoring/puttering/fixing
matthewmosse:
On my various 125s I have used some budget shock absorbers and been happy enough with them, new cheap, better than old and leaking. Some are rebuild able, but on the smaller bikes less often, probably not cost effective even if possible. If yours are leaking because the chrome rods are rusted or worn and damaging the seals then that would need repair or replacement. Easier to buy new shocks.
Ko En:
Thanks Matthew,
I'll give those cheap shocks a try some time soon.
Funny thing: I used Shell V-power which I liked, it seems to run a bit more silently or smoother, hard to pinpoint exactly what the difference was. But the milage I got from that tank was much less than what I normally get, at least 40 miles less on a tank.
-Is that normal or should I be searching for a leak? ;)
Cheers.
Navigation
[0] Message Index
[*] Previous page
Go to full version
