Author Topic: Air filter case washer 17318-323-010  (Read 11800 times)
Offline Seabeowner
Re: Air filter case washer 17318-323-010
« Reply #15 on: August 14, 2018, 09:00:47 AM »
It was fitted to my all original US K0. It doesn't do a lot, maybe just keeps the two bits of plastic flat where they bolt together. I bought one for my K1 when they were available, but think they were quietly dropped. Doesn't appear on later models.
It's 0.42mm thick.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #16 on: August 14, 2018, 09:23:20 AM »
I think Oddjob has answered this question but it isn't fitted to our UK CB500/4 K1. The parts fiches are not to be believed at times 😁😁😁.
« Last Edit: August 14, 2018, 09:26:49 AM by Nurse Julie »
Offline Seabeowner
« Reply #17 on: August 14, 2018, 11:19:46 AM »
I think it was possibly dropped before the K1s, but it does show on all the parts lists K0, K1, K2.
One thing I have never seen is a rubber bit over the front top of the air cleaner shown on the p/l.
17315-323-000. According the parts list it was fitted to countries A, D, E, F. Clauss Studios sell it.
Offline petermigreen
« Reply #18 on: August 14, 2018, 04:03:53 PM »
My 500 has that rubber piece. May also have the metal plate as well, need to check.
« Reply #19 on: August 14, 2018, 08:14:31 PM »
Just for Seabeowner
Can't make out the flat plate but seem to recall one? ???
Peter
Offline sye
« Reply #20 on: August 16, 2018, 11:50:23 AM »
Here's the result of my efforts, all dimensions are correct although it could look a little prettier I suppose. Fits fine and seems to do the job. Just waiting a day or so for the paint to dry fully and then assemble.
« Reply #21 on: May 08, 2019, 12:51:43 PM »
I have my airfilter case apart and forgot how that part (17318-323-000) should be oriented. You have to look well, but the pic in the CB500K2 (ED, F, G) parts list seems to suggest it protrudes into the chamber and not into the hole. https://images.cmsnl.com/img/partslists/honda-cb500k2-general-export-f-16-air-cleaner_big3IMG01171138_b55e.gif Is that right?
Offline sye
« Reply #22 on: May 08, 2019, 02:29:49 PM »
Yep, into the chamber is correct and the filter is slanted at the front to accommodate it.
« Reply #23 on: May 09, 2019, 06:52:22 AM »
Thanks Sye.
« Reply #24 on: May 09, 2019, 11:16:44 AM »
... and the filter is slanted at the front to accommodate it.
I am not sure I understand what you mean by that... (forgive me I'm not a native speaker)
Offline sye
« Reply #25 on: May 09, 2019, 11:30:51 AM »
There is an angled slope on the bottom front edge that gives a little more clearance for the threaded part to protrude into the air filter case. I've attached a picture that may help you visualise it.
« Reply #26 on: May 09, 2019, 12:27:40 PM »
Aha! Never noticed that. Thanks Sye. I learn everyday.
