Author Topic: Out and about in Wales 2019  (Read 27257 times)
Re: Out and about in Wales 2019
« Reply #15 on: September 22, 2018, 05:05:24 PM »
   any one doing this ??
  I am booked in and also B&B
Offline matthewmosse
« Reply #16 on: September 23, 2018, 12:38:40 AM »
I'm 30 miles off Welshpool if anyone needs a local ish place to park up with cctv to keep the bikes safe, dry leathers in front of a fire etc, house is a bit small, but room for plenty of tents and a bbq if the weather allows. Kettle and tea redily available. Word of warning if visiting and not used to the area, lovely roads for bikes but keep the tank filled up when you get the chance, especially after 7pm, easy to find yourself lots of miles from an open petrol station. Like way outside of the range of a reserve taps dregs of the tank situation. I used to reacon on 30 miles in reserve, give or take from my 500/4 on local trips, some of the back roads use range up with the hills. If I hit reserve on my way back from work it was turn around and head back to town to refill or fill up with a Jerry can at home territory. Between my place and Hereford after 7 pm was pretty well dry for filling stations. Even daytime there's only 1 or 2 or you end up diverting using a sat nav.
« Reply #17 on: January 04, 2019, 04:20:41 PM »
  first ride out this year,had to take it easy,as I am bedding in new tyres ,
 the sunshine was lovely,but no heat !!!!!
« Reply #18 on: January 04, 2019, 05:26:27 PM »
Were is all that sunshine John, bloody only 2 degrees here with cloud all day  :(
« Reply #19 on: March 24, 2019, 07:52:06 PM »
I'm doing North Wales in July.  Me and two other guys on 400fours
« Reply #20 on: May 02, 2019, 04:38:12 PM »
this weekend,on "Star wars" day ,I will be doing the Welsh National Rally,
 Starting at Welshpool ,
 My first check point is at Denbigh,A&D Motorcycles ,LL16-5TQ,  guessing around 10.30am ish
  next check is at Colwyn Bay KTM, LL29-8PU, around lunch time
 last check is Tan-y-Bwlch station, LL41-3AQ,
 inbetween these visits are 10 clues at various towns/villages to answer ,
 hopefully I will have time to stop for an ice cream at Criccieth ,
 then back Welshpool for a finish .
 typically ,its going to be cold,and hopefully sunny
« Reply #21 on: May 03, 2019, 07:18:55 PM »
Ok.I am at Welshpool.
It's got cold and a few showers.
The bike needs a clean already.
« Reply #22 on: May 03, 2019, 08:04:35 PM »
Been a pretty good day just down the road, just a few specks of rain. Nice and warm. I was rendering a straw bale wall so needed a wash badly, coated in lime render. Hopefully you'll find it warmer over towards the coast - seems we get warmer weather  with the sea breeze around this time.
Offline Woodside
« Reply #23 on: May 03, 2019, 08:26:02 PM »
Nope don't clean it..
Looks genuine...they all looked like that back In the day..
Offline Woodside
« Reply #24 on: May 03, 2019, 08:27:34 PM »
No2 looks hot
« Reply #25 on: May 04, 2019, 07:00:52 AM »
No2 looks hot
When I fitted the 4 pipes. I had to panel beat no2 pipe to clear
The Peter Furlong enclosed chain case.
Just off to consume a full Welsh breke.
Keep me going all day.
Lovely sunny AM.but chilly
« Reply #26 on: May 04, 2019, 07:36:54 AM »
Chilly !!!
Dusting of snow on the hills
« Reply #27 on: May 04, 2019, 02:42:41 PM »
What a crap day.took this pic in the start area.went to sign in.
Came out.
Started the bike.blipped the throttle. And then silence!!!
Engine would not start.checked under tank.everything seemed ok.but
nothing happens.
Starter spins it over. Plenty of fuel.
AA recovery to home.
More details when I find them
« Reply #28 on: May 04, 2019, 03:01:53 PM »
Oh no what a pain after all the effort you've put in to take part.
Hope they get you home OK.
« Reply #29 on: May 04, 2019, 03:33:41 PM »
Home.ok.great service.
Had time to take tank off.checked coil connections.
Found one loose.pushed it back in.bike now runs perfectly.
Crimped the joints. Making sure the damn things don't shake loose again.
JEEEZZ    what a day.
Obviously the force was not with me !!
