Author Topic: Yankee Doodle not so dandy CB400 rebuild  (Read 28319 times)
Re: Yankee Doodle not so dandy CB400 rebuild
« Reply #45 on: October 06, 2018, 01:04:23 PM »
Im putting half a hand up as I never new the spring and ball were there until we had an in depth discussion on here about what made the 'click'  when moving the lever up and down. I was ready for the little blighters when I took mine apart.
Offline Skunky
« Reply #46 on: October 06, 2018, 01:39:55 PM »
Still, The carburettor rebuild is nearly complete. All the carbs have been scrapped scrubbed and cleaned in an ultrasonic cleaner, tops and bowls polished, new jets needles and seals fitted and reassembled. Then Disassembled as the light dawned on the missing spring. A manual set up bench set up to get it as close as possible to factory and then should be able to get a start. One tip I could pass on. I managed to rescue the floats but the pins were of course ruined. I bought a 2mm model makers brass rod from fleabay for £2.99 for 200mm and cut my own pins rather than pay £2.50 each for them. Still got enough for another rebuild  ;D. Got my eyes open for a set of Vacuum gauges but in no hurry.
Honda CB400F USA
Triumph Thruxton 900
BMW K100 Custom Buils
Offline Skunky
« Reply #47 on: November 15, 2018, 06:43:39 PM »
Hi Honda lovers, It’s been a long time since my last confession. I finished the carburettor rebuild some time ago and it’s been sitting in the garage calling to me.
Before I start the strip down, I wanted to gauge the engine condition. As previously mentioned the engine turns over and has compression. I put the carbs back on hooked it up to the car battery and tried to start. She popped and spluttered and then
https://youtu.be/CKfXo_9H4Lo
The Engine doesn’t sound too bad for a 44 year old.
Honda CB400F USA
Offline Rozabikes Tim
« Reply #48 on: November 15, 2018, 10:34:39 PM »
Nice one. Great feeling when they first fire up!
Offline Skunky
« Reply #49 on: March 30, 2019, 09:28:01 PM »
Hi Honda lovers
Spring is in the air and I have returned to my CB400 project, which to be honest has been languishing in the garage since October. I had some work to do on my Triumph and still have some to do on my beemer.
Anyway, last year I got the Honda running and was happy with it. The Engine has good compression and ran well.
Today I stripped the Honda down to the frame . Everything came apart well engine out, forks, wheels even the loom.
I turned the frame over to remove the stand and that’s when I discovered a massive problem. When I bought the bike I noticed some iffy looking welding on the side stand. I assumed that it may have had a problem and been botched. Seems I wasn’t wrong😢.
[ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Honda CB400F USA
« Reply #50 on: March 30, 2019, 09:33:32 PM »
« Reply #51 on: March 30, 2019, 09:41:14 PM »
Whoa, it's not often you see such a classic example of pigeon-shit welding  :)
Or perhaps even worse and verging on hemorrhoids.
That's not good is it.
Offline Skunky
« Reply #52 on: March 30, 2019, 09:41:46 PM »
I know. Should have heard the language 🤬🤬. I have a welder/ fabricator who has done work for me before. I shall take it to him to see if it can be salvaged. If not I either look for a frame or scrap and sell the parts.
Honda CB400F USA
Offline Moorey
« Reply #53 on: March 30, 2019, 09:45:29 PM »
It looks like all the original bits are there. A grinder and a competent welder will sort that easily enough.
Offline Skunky
« Reply #54 on: March 30, 2019, 10:07:58 PM »
In going to go over the frame tomorrow cleaning and de-rusting just to make sure there's no rot. I think a P.O. Must of hot the side stand really hard. Luckily the frame seems true so it should be OK
Honda CB400F USA
Offline Andych
« Reply #55 on: March 30, 2019, 10:39:28 PM »
Wow... that makes my side stand area look good... relatively speaking...
Actually... looking at my pic again.. I think they are almost on par..
1975 CB400 - Project
1978 Yamaha SRX250 - Project
Offline Skunky
« Reply #56 on: April 05, 2019, 01:20:08 PM »
Today I’m a much happier Skunk 😁
Picked up my frame from my welder in Derby and he has done a great job [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Honda CB400F USA
« Reply #57 on: April 05, 2019, 03:25:54 PM »
Very nice job. You are back on the road to recovery. Keep the progress photos coming.
If the welder is willing to take on this type of work it might be a good idea to post his details on the parts and services section?
Offline SumpMagnet
« Reply #58 on: April 05, 2019, 06:47:51 PM »
Considering what your welder had to start with...he has done a good job of recovering that!
CB750F2 - in pieces
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #59 on: April 06, 2019, 12:33:17 PM »
...the bigger the blob, the better the job.
Surely... 😂
